120k Mile Service
120k Mile Service
Where should I take my Z for this service? Should I take it to the dealer or is there somewhere else that i can trust to do a quality job for this? About how much should I expect to pay for all this?
Thanks
Thanks
Captain, that was without the timing belt change right? The dealer will be VERY expensive. I'd look for a shop that specializes in Z's around your area or find another Z enthusiast who's done it before and DIY with their help.
CaptianZ, If the dealer did all that is required on a Z32 engine @ 120K, for that price you got one hell of a deal. At the Nissan dealer where I live the 60K timing belt change and auto/tensioner pully was $500 only. The 120K is a little more intense, it requires the above with the other two idler pullys and this could add another $250 to the mix, not to mention the coolant system hoses, bad vacuum hoses, drive belts, oil & filter change, air filter. The factory list goes on a little more.
fyi........... a diy kit from courtesy nissan is $354. it does include water pump and thermostat which probably aren't needed. So it'd be $250 in parts and you should still buy all new hoses. you could probably get all of these parts elsewhere for $150.
This is what I'll be doing.
VERY true 91, but this is a good learner DIY job. It can be tricky with the timing belt, and it all takes A LOT of time, but you could do it. I would try to find someone who's done a timing belt change before and have them help you with that part of it.
91, don't forget I'm cheap. With a properly maintained cooling system the water pump should last way longer than 60k miles. Closer to 200k miles nowadays. And you know what kills water pumps the fastest? Especially older ones? Putting a new belt on and tightening it too tight.
