Can I run just one BOV???
I tried the web and on this site with no avail. My friend has an MR2 Turbo. He runs a HKS SSQV Blow off Valve and claims its making his car run rich. He tells me his car from the factory is setup a little rich and that venting the air makes his car run richer. He tells me my car will run rich if I add BOV's. Doesnt make sense because the O2 sensor should be able to relay to my ecu that I'm running rich and change the A/F mixture right. Or does the change in air from the MAF and what actually enters the engine mess things up?
Either way, I read on a post here that a pair of BOV's may make the idle a little rough.
Three things bring me to this question:
1) I 'd rather not run rich (tunes are expensive)
2) Rather not have akward idle
3) Money
Can I run one BOV and leave the recirculator on the other side. I dont plan to make monsterous HP with this car. I want a BOV solely fot the sound (I'm trying to find a nice adjustable BOV, incase you know of some plz let me know)
Call me dumb I dont care I want that sound!
I figure one BOV will be lighter on my wallet, and any negative affects would be cut in half. Also it would be half as loud (in theory)
I could run a Y splitter between the side that has the recirc. and a long hose to the other side to equalize the air. (if the hole that the air vents back into isnt plugged or removed when installing the BOV on this side) But I figure it wouldn't be needed because the hoses just run into the intake either way.
Thanks Tim
3) Money
Thanks Tim
I know its not a MR2 just giving you info from where I got the idea that it might make it run rich. YEs I've looked under my hood I know where the recirc's are and It seems like theres no reason I coulnt run just one Bov
Don't be a ricer.
And your car will run rich for a brief moment during shifting with blow off valveS (notice the plural form), but it is nothing to be concerned about.
Please go to twinturbo.net and proceed to read as much as possible on the subject of modifying twin turbo Z32's.
z32s do not respond favorably to anything done half-assed. if you must have the Fast and Furious PSSSSSHHHHTTT, get two quality BOVs. if money is at all a concern, i'm afraid you picked the wrong car. really, a z32, tt or not, is not a great choice for a 19 year old anyways.
Don't be a ricer.
Still know a reason why a single BOV is no good? I want it tasteful. Not the loudest possible BOV on the earth to attract a bunch of attention. Just something that feels good to my ears while a take her for a cruise during the night or during the summer days coming up. That sound echoing off the trees of a mountain pass or a tunnel is one of the most beautiful things I think can enter my ears. (Or ear since it wouldn't be plural BOV's)
Tim
Tim
A. it's half-assed. bad news on a z32.
B. the way the engine is designed, one turbo feeds one bank of cylinders. to have a different setup on each side will cause the cylinder banks to behave differently. this is not a good thing. MR2s are set up completely different. you can't use them for comparison.
Also mines a 96' so she's only 12yrs old
Any recommendations for a quality set that are reasonably quite or preferably tunable?
Tim
that really does not matter. these cars need a good deal of maintenance, and it is not inexpensive. the long standing z32 motto is "always set aside at least $2500 for maintenance at all times".
I spend like 3K every 60,000 miles for belts, fluids, and plugs. Synthetic oil every 3000 miles or when it looks a lil dirty. And watch for leaks that will no doubt be costly (given the nature/design of our cars)
I'll look into the maintenence more so I know what to expect, but the above cost to drive such an amazing car seems like a small price to pay.
Tim
I can't find any instance of 1 BOV
On the Z, seems like 2 is the standard. I guess you could use one if you had one intercooler for both turbos. There just isn't a connection equalizing pressure between the charge air. Take a few minutes if you haven't already and look through the vendors on the z32 info sticky. I'm sure you can find something there at a much more reasonable price than 600$ per unit.
As far as RICER the people that stated their opinion about that on this post aren't even from your generation. I'm surprised they didn't say "Kids these days with their damn BOVs ruining the neighborhood"
You don't play Quake with that moniker of The Muffinman do you? If you do, this is Goofunk saying "I've killed you before"
Let's review
Do you change only the left bank spark plugs? Do you clean only the right bank fuel injectors? Do you only use 3 cylinders of a 6 cylinder engine?
Lighter on the wallet, but $$$ is not an issue?
I suggest doing research (like reading car / mechanical related books) before doing something that may destroy your car.
FYI... You change conventional motor oil every 3k miles. Changing synthetic every 3k is a complete waste of money, time, and resources.
Moneys not an Issue
I dont know much of anything about Turbo set-up's let alone the Z's set-up other then it's complicated
You're talking about running a setup that will create an IMBALANCE in the intake system and you don't think it can cause some problems? :::sigh:::
The VG30DETT was designed as two inline 3-cylinders with a common crankshaft... anything that you do to one half of the engine MUST be done to the other half of the engine. Get two, or start writing your "I blew my engine because I didn't listen to you" post now so that you can post it immediately when it happens.
Synthetic oil
the turbo Z hasn't even got 4 quarts of oil that it circulates to cool, both the engine and turbos. When you change the oil in the turbo z you use less oil than the NA Z. Now the Z isn't a Minicooper it wont go 13K between oil changes but its true you don't have to change the oil every 3k miles, I'm pretty sure I wouldn't go 7000 miles between changes like it says on the oil cans. Some where in the middle would probably be just fine. 4-5k miles between changes on fully synthetic oil. There are some nice oil filter and oil(s) write ups on this site. I would encourage you (The_muffinman) to look them up and review them.
I'm not a ricer my other ride is a 65' Mustang that I built with my dad. I hate body kits (lips are ok) and Pretty much anything other then stock tail light make me want to yack. Fart cans annoy me, Wings a mile high and stickers dont add horsepower. Wal-Mart and Kragen are not approved places to buy any upgrade product (except K&N filters). Liscense plate frames that read a banner like Drift it are ridiculous and are a waste. Ridiculously bright colors in the interior on shift boots and parking brake boots are terrible. I dont know what else to say really mabye I'll rant more later.
Tim
Tim
Originally Posted by raythenegr0
You would still hear one through both ears...unless you're deaf in an ear, if thats the case than I'm sorry.
I dont think it's too costly.
Tim
Tim
... we're clearly not dealing with the brightest crayon in the box...
I came to you with a question. I'm here to learn why would you give me such a hard time.
In the case about the one ear cr*p I guess I meant I'd here it from one side more then the other, IDK it was late.
Oh yeah I said one would be lighter on my wallet because that is a fact. Knowing that I will do harm to my engine with just one makes it not an issue to spend the extra money as in "$$$ not an issue" I'm sure you're no millionaire and if you could spend half as much on something you would appreciate the cash not being spent.
I've always read and been told on turbo set-up's oil should be changed @ 3000 miles. Since the car was well taken care of by the previous I would like to prevent anything harmful from happening to my engine, It's "cheap insurance"
Seriously I'm here to learn if I say something that deosnt sound right check me on it but plz do insult me. I'm pretty sure were not children. If were debating something then I can see why an insult might fly but All I did was state an opinion and idea I never said any info given to me was incorrect or refuted it.
Tim
either way like Zlover Said, I once had the stupid idea of a single exhaust. you now got the stupid idea of a single BOV. just get that one, save up buy another one and install them at the same time.
-Juan
When you try to save money on the Z32TT, you WILL end up spending more later on when something breaks as a direct result of you cutting corners.
And yes, I am an *sshole. But I'm a helpful *sshole, so people usually don't mind it.
