Car runs outta power
Old 09-05-2009 | 09:49 PM
3riCJbOi's Avatar
one sound fits all
Hey guys my Z is acting up
seems like the power keep going away.
had to jump start the car a few times already
had battery and alternator replaced and yet the problem still here
what else can be wrong with the car?
new battery and new alternator and the car still runs outta power.
it was fine for a few days but it acting up again
help! dont know what to do now
Old 09-06-2009 | 02:50 AM
skib's Avatar
This facepalm's for you!
something in your wiring causing a drain in your battery (assuming both battery and alt are working correctly)
Old 09-06-2009 | 08:59 AM
3riCJbOi's Avatar
one sound fits all
hmmm you think how much will it cost to fix cause i already spent some money on the new battery and atlernator. anyone know an estimate soo i know what im looking at
Old 09-06-2009 | 09:48 AM
3riCJbOi's Avatar
one sound fits all
Also when i changed the alternator it worked fine for a fews days then it started to drain out again. Hope someone can help me. thats pretty all the information i have.
Old 09-06-2009 | 12:16 PM
KasbeKZ's Avatar
Pr0n Addict
i'd check all the wires especially around the alternator for frays and breaks. also get a test light out and start trying to find your draw. easiest way is to just put the test light on the battery and start pulling fuses until it goes out.
when you say running out of power, it usually means actual power. not battery. it would be easier to understand you if you said "my battery keeps going dead".
Old 09-06-2009 | 12:27 PM
3riCJbOi's Avatar
one sound fits all
Thanks for the info, I check the wiring around the alternator they seem just fine. I jump started the car this morning and let the car idle for a bit and then took it for a few test runs. And now it seems fine again.
It was running fine three days ago too, but last night when i tried to start the car it wouldnt start. So yeah the wirings around the alternator seems good and the fuses are good too. Any other idea? Thanks for all the help too.
Old 09-06-2009 | 12:50 PM
skib's Avatar
cant help ya on that one. none of my Z's have ever seen a shop (you get raped for teh monies there) so I build/fix everything on my Z's.
Old 09-06-2009 | 04:57 PM
KasbeKZ's Avatar
Pr0n Addict
i didn't mean fix the fuses. i meant pull the fuses one by one while you have a test light on the battery to see which one makes the test light go dimmer or out.
when the car is off, the test light should be very dim. just that it's on means that the battery is being drained. but it's usually on just because of the clock and radio and i believe maybe a tiny bit of juice to ECU?
but you evidently have a bigger drain that's not usual. so hook that test light up with the light on the + terminal and the clamp on the hood or something. it should be lit. if it's not, put the clamp somewhere else. then start pulling fuses. one at a time. and looking each time to see if the light is dimmer than before.
Old 09-08-2009 | 11:17 PM
3riCJbOi's Avatar
one sound fits all
The car was running fine again for another day or soo
but i was driving tonight and the car was tripping the battery was draining out
my lights started to flicker and the deck goes on and off.
If the car is on and it has an issue like that can it be a defective alternator?
Can it be that it isnt charging the battery properly?
Old 09-09-2009 | 02:22 PM
KasbeKZ's Avatar
Pr0n Addict
battery doesn't come in and out of charge fast enough to make the lights change. and alternator not working would not cause that, because when it stopped working everything would keep working and gradually dim.
the problem is a connection. somewhere. like i said, test light on battery, pull fuses. it will tell you where your problem is. test lights are about $2 at harbor freight.
though, if i had to guess, i'd say it sounds like it's right in your main line coming from the battery. one of the two anyway. you said the car would jog right? that's what tripping meant?
shaved300zx
08-22-2009 06:40 AM
SpeciallySpiked
04-16-2006 11:15 PM
pete8717
01-27-2006 07:32 AM
ContagiouSzxt
08-11-2002 04:29 AM
Canadian_ZED_X
07-29-2002 08:50 PM
