Check out what I got
Old 09-03-2010 | 11:54 AM
  #101
BlueKitsune's Avatar
Intrawebz Wizard
Of course the clutch and flywheel are fine after 10 miles.
Thats what I sorta figured. but idk what kinda flywheel that is. Knowing the guy that bought all the parts for this car, he got it off of ebay.
Old 09-03-2010 | 12:05 PM
  #102
ZLover4Life's Avatar
Encyclopedic Knowledge
When it warps, it'll be sufficient reason to buy an RPS segmented flywheel.
Old 09-03-2010 | 05:09 PM
  #103
Amazingly yes! They just were bypassed and not hooked up at all.
You wanna sell them?
Also, don't forget to have your pressure plate and flywheel balanced.
Old 09-03-2010 | 06:31 PM
  #104
domsgarage's Avatar
Tough Guy
Late response, but harbor frieght has a compression test kit for 20 bucks.
Its pretty good even though its cheap.
Old 09-03-2010 | 07:10 PM
  #105
Intrawebz Wizard
I'd rather Do something NOW then Later to be honest... Last thing I want is to pull the trans out after only a few thousand miles.
Uh, If I wont be needing them when I get my EBC, Then sure.
And I think I'll go the "Better safe then sorry" route and get new ones.
Yes VERY to late lol But that will be helpful for later none the less so thanks for the info!
Old 09-03-2010 | 07:25 PM
  #106
Intrawebz Wizard
Ok I have. Turbos that are withing their wear limits that also have the manifolds, quarter pipes, and oil lines still. (Keeping the coolant lines and the in and out of the compressor side) Good Stock injectors that have solid uncracked pintles with the rails. (keeping the lower plentum and getting 300 Degree rails) and the dual core FMIC with pipes.
How much do you think all that stuff is actually worth so I can put up a fair price for it and get it out of my shop?
EDIT (instead of a 3rd post): the stock early TT wing. IS A BITCH TO GET OFF I knew it had some glue but holy ****! I'm shocked I didnt ruin anything more then the paint and the wing! Anyways I removed it cuz I was getting scared of it. I could see rust peaking around the lips of it and when I pulled it off that entire steel plate on the inside was rusted so badly I could poke though it. thankfully the car itself is fine. I have no clue how I'm gonna get all this dried rubberized glue off tho...
Old 09-03-2010 | 08:09 PM
  #107
The EBC has it's own solenoids that control the boost.
Old 09-03-2010 | 08:15 PM
  #108
Intrawebz Wizard
Ah ok. uh I honestly dont know what their worth if anything to be honest. lol
Old 09-03-2010 | 09:28 PM
  #109
$15 shipped to CA?
Old 09-03-2010 | 09:33 PM
  #110
Intrawebz Wizard
$15 shipped to CA?
Deal. I'll PM you the info
Old 09-04-2010 | 07:49 PM
  #111
Intrawebz Wizard
How the hell do you get the exhaust side of the turbo off short of beating on it with a rubber mallet??? I got the bolts off of it and everything. is it pressed in there or something?
I'm trying to take the Exhaust side and compressor side off, mainly out of curiosity, and I found you can still buy new CHRAs (what does that mean? I'm guessing its the core part of the turbo with the blades on it) for fairly cheap. and I might rebuild my stock ones.
Old 09-04-2010 | 08:56 PM
  #112
Complete Housing and Rotating Assembly. Includes the center section including bearings, and the compressor and turbine wheels.
Regarding removing the turbine housing, I've never had to do it... google it.
Old 09-04-2010 | 09:01 PM
  #113
Intrawebz Wizard
Ah alright thanks!
And I kinda figured this is an odd topic lol Maybe I'll ask on TT.net first
Old 09-05-2010 | 12:08 AM
  #114
Put it in a vise, soak it in PB blaster and carefully beat it off with a hammer.
Old 09-05-2010 | 12:12 AM
  #115
Intrawebz Wizard
I already figured it out thanks to TT.net lol
Old 09-13-2010 | 03:15 PM
  #116
Intrawebz Wizard
I just found out I can get Z1 to send me an entire front clip from a JDM TT send to my driveway for about $6000 (with shipping) and that will have everything I need to fix this Z right. Thats cheaper then what I was looking at just to buy all the parts I need, course I was looking at higher performance parts tho...
Hmm...
Old 09-13-2010 | 05:46 PM
  #117
Hmm...
Screw paying $6k for a front clip, you could buy a decent TT for that price.
Old 09-13-2010 | 05:50 PM
  #118
Intrawebz Wizard
I just tallied up my parts list for my 500-600HP rebuild and I'm at closer to $8K or $9K course thats quite a bit ore power then a stock TT
Hmm, buy a new new TT, Rebuild the current TT, or get a JDM TT front clip.
Old 09-13-2010 | 06:02 PM
  #119
If you have $6k in cash I would look for a new TT and part out the old one, or get a TT clip.
Old 09-13-2010 | 06:25 PM
  #120
Intrawebz Wizard
I'm buying parts over the course of a year. But if I rebuild my current TT, for about the same price as a clip/new Z I'd have between 500 and 600HP.
So I guess I'll just keep with the idea of rebuilding mine.
Old 09-18-2010 | 09:39 AM
  #121
Intrawebz Wizard
lol I think I stumped nearly everyone at TT.net. or I asked an incredibly stupid question.
Old 09-18-2010 | 09:43 AM
  #122
$6k for a front clip? Try $3K.
And what question on tt.net?
Old 09-18-2010 | 09:59 AM
  #123
Intrawebz Wizard
Oh sweet! Thanks for the link, I might just do that and keep with stock power for now lol
And the question was asking if I can use a manual trans alt/trans harnesses on an auto trans car so I can clean up the engine bay.
Old 09-18-2010 | 10:32 AM
  #124
I don't believe you can use a manual harness on an auto trans, because the auto trans has additional electronic input requirements.
And yes, the front clip is always the way to go when converting - you'll have everything you need (except fuel pump and FPCU), just have to swap it all over.
Old 09-18-2010 | 11:35 AM
  #125
Intrawebz Wizard
Ya, I was looking at the cost of everything I need to replace and I was at almost $9K in parts, course that was all new performance parts lol.
and uh, the Auto trans didnt play and roles with the ABS system did it? Ever sense the swap the ABS light never turns off even tho the brakes are fine
Quick Reply: Check out what I got
