Coil pack wiring
Old 11-03-2013 | 07:02 PM
LogansZ's Avatar
Coil pack wiring
So I got new coil pack connectors cause my old ones were old and brittle.And of course I Replaced them and accidentally got the wiring wrong on a couple.. Sounded like it was running on 1 cylinder. Now im not sure how every wire is suppose to be sitting in the connectors. If someone could take a look at theirs and help me out on fixing this back to normal that would be amazing.
Old 01-20-2014 | 09:44 PM
SebastianPavich's Avatar
i can send you a Link to a ECU diagram that will show you the coil pack connector wiring, but it could be a little confusing on which way the two end wires go on which end of the connector, the big Black wire is the middle pin for sure. look at it this way, with the coil pack bolted in and the connector plugged up, the small black wire on the right, and the big black wire in the middle, colored wire on the left, hope that helps
http://www.ttxtz.com/tech/lee/ECCS_colored_m.gif
gojoedobb
10-21-2012 01:15 PM
Afrikaaner
09-22-2009 08:54 AM
srimes101
05-25-2006 03:20 PM
ihc300zxt.t.
02-14-2006 02:47 PM
craftm
01-15-2005 06:30 PM
Quick Reply: Coil pack wiring
