Drive Belts
#26
Originally Posted by emo236
never replaced it, just delt with it. and that's good that you had a quiet tensioner.
86zMan, thats called belt dressing.... I use it to help isolate the right belt, but sometimes it will stop the problem all together...
#27
i know what belt it is because when someone pushes the gas i can see the belt slipping.
#28
You mean to tell me there were people out there who thought they had a failed timing belt tensioner and continued driving?!?!?!?!?!!?!?!?!?!?!?!?! Good god..... That explains alot about the info on where it's coming from....
"If you hear an annoying squeak from the front of the engine when the car is cold, its the timing belt tensioner. If it bugs you, buy another car or plan to change the timing belt early, $500 (including the tensioner, $250 without). The timing belt only needs to be changed at 60K miles. But, you have to take the timing belt off to replace the tensioner. It won't hurt to wait, it just makes an annoying noise for 5 minutes or so each time you start it. Nothing is actually broken."
#29
if it's making an abnormal sound, it isn't operating correctly.... therefore needs to be investigated / checked out. And I knew if ANYTHING wasn't operating correctly on my car, ESPECIALLY when dealing with something as crucial as the timing belt.....
#30
#31
timing belt tensioners don't squeel either.... it has nothign to do with the timing belt or related parts / accessories...
All the timing belt tensioner does is keep the timing belt tight. Let me provide an analogetic example.
Mechanical Engineering lesson over!!
#32
Also if you don't believe me, Go to a Nissan dealership. Ask a tech this question and if he doesn't know ask him to look it up on Assist under Symptoms; TSB/TIPS Anytime there is ANY regular problems on ANY of Nissans vehicles it is put on the Nissan Assist Network for all the Techs all over the world to compare symptoms and fixs.
#33
A. The hydrolic tensioners are sealed units on the Z32, which mean the lube isn't going to "wear" away. Either the seal will fail and it will leak out, or the bearing will get too hot and it will solidify the grease inside. Not impossible for the lube to "wear" away, but there is a reason for it.
B. Bearings do not start squeeling, then usually stop.
C. Belts are normally temperature sensative, bearings aren't really bitchy about that.
Also, bearing and belt squeels have distinct different sounds. Not much of a difference of the loudness of them...
Oh yah.
D. why are you bringing up an old dead post? If you would of read, it was already established in the first 3 posts the problem was a drive belt. I"m curious now as to why a timing belt tensioner was even brought up.
E. my original statement of, you have people who've delt with THOUSANDS of Z's that still drove their Z's around with timing belt tensioners with, for the sake of Outkast's posts "failed bearings" in them and they didn't replace them... Having a hard time believing that still.
And just cause you "work on cars" doesn't mean you know what your talking about. A NISSAN dealership (you didn't even say if you worked at a Nissan dealership) here managed to EF my Z up pretty bad, and they "work on cars all the time."
*Fine Print* I reserve the right to be wrong, other people should too. I also reserve the right to think your head is up your ***, as for this thread, this is my last post on it because i outlined my point clearly enough for someone with IQ to understand the points that were made. (the original point being you can get drive belts from autozone that work just fine..)
#34
Sorry, wasn't gonna post on this thread again, but outkast had something to say. Yes, you reserve the right to be wrong, and he does to be right sometimes. Be skepitcal, you should be, but I suggest researching what happens to a lot of Z's, not just your own.
#35
You mean kinda like wheel bearings?
Please don't tell me that you think a wheel bearing and a belt tensioner bearing are even marginally similar.
Emo,...I think every person who has ever posted a question about squealing belts has gotten your response about the tensioner squealing. If a tensioner actually can make this noise; which I'm still saying it won't, unless maybe you put 300k miles on one, and since nobody here except you and Ludacris has ever actually heard it, don't you think that the accessory belts are a far more likely diagnosis???? Come on, you're a smart kid. Give people an answer that is most likely going to help them, not make them think that these cars are just repairs waiting to happen.
#36
