Fuel pump fuse?
Fuel pump fuse?
I was wondering where the fuel pump fuse would be, or whether or not it is located in the module for the fuel pump relay. The car started fine yesterday, and started this morning for a few seconds and then died. Now it will not start at all. It sounds like a fuel issue, so I went to see if a fuse blew for the fuel pump but could not locate it. I located the relay under the kick panel, and it does indeed click when the ignition is turned on. I'd rather not have to replace the fuel pump, I am hoping that it is something as small as a fuse. Any help as to where it is located or anything else would be appreciated. I hope it's not the pump itself.
have you determined it is even fuel?? unplug the main fuel line infront of your fuel filter, point it at the ground, have a friend turn the key on then off super fast, that should turnthe fuel pump on for a second, see if fuel comes out, if not, then yes, it is a fuel pump issue.
sameerb1
03-20-2011 05:21 AM
derekinthez
07-21-2007 01:53 PM
ern
10-20-2006 07:01 AM
chrischicoine18
05-25-2006 11:46 AM
