Harmonic balancer
Old 08-05-2013 | 12:23 PM
Artyzb29's Avatar
Harmonic balancer
I have a 2+2 automatic 1990 300zx non turbo, I'm having trouble getting the bolt out. If anyone can help me out I would appreciate it.
Old 08-05-2013 | 12:46 PM
Welcome to ZDriver!
The crank pulley (harmonic balancer) bolt is torqued on at ~150ft/lbs. Usually you need a beefy 1/2" breaker bar and impact socket to get it loose, or you can brace the breaker bar against the frame rail and crank the engine super quick. Just make sure you've placed the breaker on the correct side so it will loosen the bolt. And disconnect the coil packs.
Old 08-05-2013 | 12:55 PM
Artyzb29's Avatar
Do I need to remove all the belts for this or can I just do it with the belts on.
Old 08-05-2013 | 06:04 PM
Rupe's Avatar
Horsepower Mathematician
Wouldn't it be easier to just disconnect the fuel pump relay?
Old 08-05-2013 | 08:14 PM
Easier, yes... safer, no. A general rule of thumb when you don't want the engine to start, is disconnect the spark. If you disconnect the fuel pump relay, there is still ~35psi fuel to burn for a few seconds. That's enough time to wrap a breaker bar through your engine bay.
Old 08-05-2013 | 09:47 PM
Rupe's Avatar
Good point!
RSuave08
04-17-2014 09:46 AM
iamericgee
07-09-2012 07:00 PM
84z31nonturbo
02-28-2008 08:32 PM
ChasZ
01-19-2004 09:03 AM
lance75_280z
06-23-2003 11:11 AM
