HICAS Fluid
Old 04-06-2006 | 01:41 AM
beez's Avatar
HICAS Fluid
Hi,I'm the proud new owner of a 300zx twin turbo 2+2
What I want to ask however is my HICAS seems to be very low in fluids after driving quite a distance to fetch the car so i'm guessing it has a leak.
I'll fix that ASAP but would me driving the car with the warning light on and low in fluids for quite some time cause any damage?
Also in some 300zx FAQ's they say you should use Power steering fluid and then others say no you must definitly use Automatic transmission fluid.
Which one is it? and does it change the answer for which year the car is? and what region the car is from? or do all 300zx's across the board use one or the other?
Thanks alot
Beez
Old 04-06-2006 | 03:05 AM
entropy31's Avatar
The Cake Is A Lie!
this is a case of RTFM. owners manual says use Dexron ATF. dont use a "power steering fluid". nissan designed the car to use ATF. that is all you should use.
Old 04-06-2006 | 03:20 AM
beez's Avatar
Just saw that a little earlier,I should have RTFM thanks for the reply though.
beez
Old 04-06-2006 | 03:24 AM
entropy31's Avatar
The Cake Is A Lie!
no problem.
Rupe
12-04-2011 12:28 PM
thxone
11-19-2006 10:33 AM
burlz33
10-01-2005 11:27 PM
nis88300zx
09-14-2005 10:54 PM
tt300z
15
01-10-2005 01:02 AM
