Hood Squeak!!! Agh!!
Old 07-31-2007 | 10:44 AM
ViperGTO99's Avatar
I tried using the search but I couldn't find anything. (I'm sure there's something somewhere, tho)
There's a squeak coming FROM my hood... I keep hitting the hindges and latch with WD-40, but it keeps coming back. It's starting to become a daily thing and it's ticking me off... HELP!!! How do I get rid of it once and for-all???
Old 07-31-2007 | 10:48 AM
WD-40 is as good as spraying water on it.
Old 07-31-2007 | 11:07 AM
entropy31's Avatar
The Cake Is A Lie!
this is common. mine does it too. you need to adjust the rubber stoppers at the front.
Old 07-31-2007 | 12:20 PM
MikeZ's Avatar
I had to lower my actual hood latch assembly. I moved it around 1/4" down and the sound went away. Not sure why it was like that tho.
Old 07-31-2007 | 12:47 PM
yup its the ruber bump stops, they suck, might have to even loosen the latch and lower it like said, its annoying noise right? i hated it.
Old 07-31-2007 | 06:35 PM
aj11fan's Avatar
wat i did was put grease on the latch. i had to regrease it couple days ago. works like a charm
Old 07-31-2007 | 07:41 PM
thxone's Avatar
Silicone Spray Lubricant...end of story.
Old 07-31-2007 | 07:51 PM
Goofyz's Avatar
squeak squeaker squeeken
graphite, lithium grease, moly-b,Silicone spray are all lubricants, WD-40, Liquid Wrench, are made to loosen rust and seized bolts.
it might be a squirrel stuck under the hood, watch the movie "The Emperor's New Groove" to learn to speak squirrel. I believe Cronk has that merit badge.
Old 08-01-2007 | 07:17 AM
Comorat2x2's Avatar
Squeekity squeek squeek squeeker?
Anyways...lol.....yeah, the creaky wooden bridge noise? Rubber stoppers most likely. I put a dab of vasaline on mine, rubbed it in instead of leaving it globbed on. Worked fine fer me.
Old 08-01-2007 | 11:48 AM
aaah, you speak squirrel too!
Old 08-01-2007 | 12:37 PM
MikeZ's Avatar
Goddammit
Old 08-20-2007 | 10:55 AM
LUCKYZ's Avatar
I lubed the hinges, latch, and rubber stoppers on Friday and no more squeaks. I used a spray lubricant but I will go back and use some white lithium grease.
GrimsLife
11-11-2010 03:02 PM
RigilKent
07-15-2008 12:46 PM
zfanman
11-27-2005 01:11 PM
iksteh00
07-26-2004 12:40 AM
jesusfreakz
09-28-2002 11:38 AM
