How to install a fuel cut-off switch?
Old 11-08-2009 | 12:43 AM
Z32FTMFW's Avatar
Anyone know of a good write-up I can go off of?
thanks
Old 11-08-2009 | 01:59 PM
ZLover4Life's Avatar
Encyclopedic Knowledge
Nope... but it's seriously self-evident. All you're doing is killing power to the fuel pump (or injectors, if you chose to do so). For the fuel pump, locate the power wire (or the ground - all you need to do is eliminate the circuit), run in-line switch, done. For the injectors, wire the powers of all six to a common power, toggle the common power, done. (If your Z is a pre-94TT or pre-93NA, the latter method has the benefit of preventing your injectors from going bad because it eliminates the constant power that causes the coils to short.)
Old 11-11-2009 | 12:58 PM
CanyonCarver's Avatar
Jack Of All Trades
I tapped into the supply side of the fuel pump relay that is behind the kick panel under the dash where the fuses are. It was easy to mount an inconspicuous switch from that area too.
Jason280ZX
12-26-2013 12:37 PM
nismo619
05-14-2012 08:21 PM
DSR300zx
08-14-2006 09:34 PM
81 Black L28E
06-08-2005 09:12 PM
MTP78Z
01-30-2001 12:54 PM
