i promise this is my last question for awhile
ok here goes, when im driving washer fluid comes out of the nozzle but only on the drivers side it doesnt squirt it just randomly trickles out from time to time. any ideas...... rod. thanks
there is a check valve
in most cars its in the nozzle itself so replacing it will probably stop the leaking, if not im sure you local autoparts store sells a little check valve that you can put inline behind the nozzle.
it's not the nozzle, it's the check valve. Under the hood, there's a white check vavle right before the nozzles... replace it (it's cheap). It's entire purpose is to stop that from happening, and they do go bad.
awesome thanks. you know i dont think ill ever have to get help from a mechanic again i can just ask the questions here and then fix it myself. i can fix pretty much anything im just not the best problem solver so thats where you guys come in you all have been there done that im knew to the z32 so it works out. if anyone here ever needs help with a vw, honda or a toyota lol you can ask me i know all in that department. haha well considering youve had an answer to every question i had so far id have to say you do know. lol
Originally Posted by napoleonzheking
mine trickles out the back, doesn't come out the front at all....
Originally Posted by forcedfedz32
Funny it happened to me but when i brake hard or floor it some squirts out not all the time. It scared me the first time but i now guess why it happened.
my first thought when it happened to me which is dumb now that i know where the resevior is located , was that the engine was getting hot and heating up the bottle causing it to boil thus squirt out the nozzle lol am i the only person who thinks of the most retarded explainations and then later looks back and is like what the hell was i thinking. haha
to everyone who says they have the same problem... take the advice I gave... replace the check valve. It's not expensive, and believe me, I KNOW how IRRITATING that problem can be when you're cruising around after just having washed and waxed the car... to stop hard only to see water drip across your hood, then drying in the sun and leaving ugly water-marks.
PurePontiacKid
09-05-2012 01:19 AM
prjctz32
15
10-17-2004 09:27 PM
