Idle issues and lifter tick
Old 04-18-2007 | 01:49 AM
ezramoore's Avatar
From: Port Townsend (Home) and Bellingham (School), WA
I was gonnah follow this little howto on how to clean the idle system and cure rough idle, but I have a couple questions.
First off, where is the car supposed to idle? I read somewhere like 650 - 750 for a manual but that seems REALLY freaken low (and its way lower than shelby's Z idles now, 900-1200ish.
Second, how do you adjust the idle? There is a screw on the TB (which is where I am inclined to look first), but it does nothing and I read somewhere that the idle was controlled by the ECU. I know I'm kinda dumb but I'm trying to learn.
Third,
I've read a couple things about lifter tick:
1st. thin synthetic oil will clean the gunk outtah the lifters
2nd. Marvel or seafoam added to your oil (in this case what oil would you use).
Thanks for the help.
Old 04-18-2007 | 09:01 AM
b300z's Avatar
caught the z fever
a manual n/a should be idling around 750 rpms. the idle screw is on the IACV in the rear drivers side behind the engine at the top. you only want to change your idle IF you know that nothing else is causing you to have a high idle.
in the case of shelby's z, you should check her IACV and ARU(linked to the IACV) to see if their resistances are in spec. if not, they can be taken off and cleaned. if those check out, theres plenty of other places to inspect and clean
lifter tick is caused by a stuck or worn out lifter. you can try adding Marvel Mystery Oil to thin out your current oil to try and unstick the lifters if that is the problem. (and afterwards)or you can try switching to a heavier oil, such as 15-50 to give the possibly worn out lifters a little extra pressure.
and heres a thread with a writeup on how to use seafoam.
https://www.zdriver.com/forums/showt...hlight=seafoam
Old 04-18-2007 | 12:46 PM
Riz Z Speed's Avatar
Administrative Brown Guy
yeah, do a just a little more searching.
rough idle is a very very very common problem and i'm sure there's a few dozen or so threads on it.
Old 04-18-2007 | 12:51 PM
yep, i cured my idle problem with what i told you in the other thread, TPS cleaning and adjusting, there is a write up on twinturbo.net i believe.
Old 04-18-2007 | 01:22 PM
ezramoore's Avatar
Thanks.
I meant to add a link to the writeup I was gonnah use but I forgot sorry. We don't so much have rough idle as we do high idle. This happens occasionally; usually when there isn't anything accessory wise causing the engine to idle high (no heat/AC, substantial electrical load, brake depressed, turning the wheel, etc.) the car will idle around 800 RPM then drop low enough that it wants to die, and then the car will correct, in a seemingly endless cycle. Is that common?
I'm gonnah try the marvel in the engine oil, but how would I go about that if the oil level is full? What ratio or how much should I use? How long should I run it before we change the oil? Whats a good brand/type of oil to use. Sorry to ask so many noob questions. Just tell me to search if this is stuff I should have found elsewhere, I just figured since I was asking a question I had already searched I might as well ask all my related questions because given the context the answers may differ.
Thanks
Old 04-18-2007 | 02:30 PM
mmmm... not really, its shouldnt drop that significantly, the high idl will come on when using A/C and junk but will stop if you hit the econ button or w/e its labeled as. and the marvel stuff, will good idea i wouldnt run it to long becuase you had that varying compression ratios so it could promote the loss, i know when i went synthetic and a lighter oil is whne my low compression started to become noticable. and give the TPS thing a try, i sound very repetitive but it really did help ALOT on my car. search it on TT.net damn YOU!!!!! lol.
Old 04-18-2007 | 02:38 PM
ezramoore's Avatar
where should i look for the TPS writeup ?
Old 04-18-2007 | 02:41 PM
i almost stabbed you throught the internet, but i luckily caught teh before rage ensued.
Old 04-18-2007 | 02:44 PM
ezramoore's Avatar
well forgive me but i'm not used to your technical jargon but how long is
to long
Old 04-18-2007 | 02:49 PM
ummm.... idk, till next oil change. aka 3K
Old 04-18-2007 | 02:54 PM
ezramoore's Avatar
got about 1500 miles till next change, should I it now or then? If I do it now how much should I put in cause the oil level is full
this_is_lettuce
11-06-2013 07:55 AM
TheRevKC
01-30-2011 10:55 AM
grey_turboae86
09-30-2005 10:14 PM
Johnny Z
02-21-2005 06:53 PM
jon93PGT
03-12-2004 10:29 AM
Quick Reply: Idle issues and lifter tick
