Info on upgraded turbos?
Old 02-29-2012 | 08:17 PM
Yardjass's Avatar
I'm swapping my NA Z and thinking of going with some aftermarket turbos while I'm at it. Finding information hard to come by though. I'm trying to do some research and learn about strengths and weaknesses of different ones but good information is hard to come by. Anybody have any suggestions or know where I could find a few good writeups to check out or places to start? I really want to get some good research in on this.
Old 02-29-2012 | 08:32 PM
https://www.zdriver.com/forums/300zx-z32-forums-7/what-turbos-32042/
Any turbo upgrade (any turbo larger than stock) is going to require an unpgraded ECU (even the smallest aftermarket turbos - JWT Sport 500s - have a wastegate preset of 12psi, which is more than your stock fuel maps can handle), larger injectors (even at 12psi, a Sport 500 will flow more cfm than your injectors can reliably compensate for), and at LEAST basic upgrades (intake and exhaust), else you risk reliability issues from choking the turbos (which will land you right back where you are now) or overboosting the engine (which will land you at a machine shop having the motor rebuilt).
Sport 500s are fantastic stock replacement turbos. Of all aftermarket turbos, they spool the fastest, and you can do well over 400rwhp with them.
Maybe Sport 500's if you already have an intake, exhaust, and ECU (you cannot run Sport 500's, or any other turbo, on a stock ECU). Otherwise, absolutely not. EVERY other turbo will require downpipes, injectors, and additional work.
Sport 500s are a fantastic inexpensive upgrade. Spool like stock and have great power output for the cost. Keep in mind, though, any aftermarket turbo is going to require basic upgrades to work efficiently (intake, cat-back, downpipes, and ECU at least, intercoolers and injectors if you know what's good for you).
Old 03-03-2012 | 08:34 AM
Yardjass's Avatar
Aftermarket turbos?
Does anybody know any good writeups about aftermarket turbos for 300's? I'm trying to do some research and check out some comparisons but information seems to be hard to find. Thanks!
Old 03-03-2012 | 10:36 AM
Rupe's Avatar
Horsepower Mathematician
Try searching for the different turbos available, and then search for reviews or writeups based on those models.
maserom
08-28-2013 08:10 PM
jaredjmoore89
56
02-10-2008 09:20 AM
SysqoeZ32
02-08-2006 06:33 PM
nis88300zx
25
11-02-2005 08:53 PM
91zxtt
21
02-03-2005 02:12 PM
