Issue with my n/a, vids inside. Please help.
Old 04-24-2008 | 11:04 AM
  #26
yeah but you never know. my friend had a similare problem assumed its the bearing, well, it was not just the bearing but also some fingers were blown off the pressure plate. stuff happens so be prepared. but it most likely is just the throw out bearing
Old 04-24-2008 | 12:22 PM
  #27
SKANLEZ's Avatar
Well I hope its only the throwout bearing when I actually get into it. The car does shift very well and it doesn't feel that the clutch it warn out. The previous owner said he replaced the clutch last year but then again he could be lying. So can I replace just the throwout bearing or do I need to replace my whole clutch?
Old 04-24-2008 | 01:12 PM
  #28
ZLover4Life's Avatar
Encyclopedic Knowledge
I honestly think it's gong to be more than the throw-out bearing. Drop the trans and see what you find.
Old 04-24-2008 | 05:30 PM
  #29
KasbeKZ's Avatar
Pr0n Addict
i also think it is more then a throw out. my throw out sounded much different. more like a grind then your click sound.
but if it is the throw out, if your disc and teeth all look good, you can change just the throw out. but, it's such a big job, that it's recommended just to do the whole clutch while you are in there
bojo68
01-27-2010 08:14 PM
SKANLEZ
04-23-2008 03:08 PM
EZDUZIT
01-21-2008 06:37 PM
rob209
03-16-2006 05:02 PM
b300z
06-13-2005 08:20 AM
Quick Reply: Issue with my n/a, vids inside. Please help.
