a knock on front passenger side strut?
Old 06-02-2011 | 02:54 PM
Samurai-Z32TT's Avatar
Ok heres what happens. Ill drive and it will sound completely fine until i run over a small bump and then right after i hit the bump i hear a loud knock and lately its been getting slowly worse but when i got the car it only squeaked and now it knocks hella loud. Any advice on what i should do to fix it? I think it might be the camber arm or the strut but im not completely sure. Any advice concerning this will definitely help! Thanx in advance
Old 06-03-2011 | 08:59 AM
Have you put it up in the air (jack stands!) yet? I suggest looking for anything "loose". But, alas, struts can make a knocking sound when they are worn out.
Old 06-03-2011 | 10:32 AM
BlueKitsune's Avatar
Intrawebz Wizard
Mine did this once before. took me forever to find and when I had it in the air I noticed the left side strut went much longer then the right. Turns out the mounting insulator tore of completely and every time I hit a bump it would sound like a loud knock.
Check all the rubber components of the suspension then check wear items like ball joints and tie rods.
Old 06-03-2011 | 02:46 PM
Well i took it to a mechanic and they told me that theres half an inch of play near my strut area. They didnt recognize the camber arm and said it could be there but when i jacked it up myself i tried to move things around and didnt find any problems. Its a loud knock too like BlueKitsune said and its not a good sound. Where can i get a bushing if it is a bushing? Would Auto Zone or Napa have it? Whats the best way i can replace them?
GODDAAMMMBATMAN
02-10-2013 10:57 AM
yor5150
03-30-2011 03:46 PM
craftm
07-12-2009 12:58 AM
Eazymac09
08-02-2004 10:37 AM
Fudabuda
01-07-2002 12:21 PM
