Nissan dealer vs local mechanic problems = sputtering + loss of power
#52
Nevermind I found for $477.65...a lot cheaper than the $707.53. How important is a warranty on the parts? I have a feeling they will say they are charging more because the parts are under warranty.
http://www.courtesyparts.com/300zx-p...996-c-882.html
#53
#55
#57
Bump..anyone?
Timing and water pump replaced..still a slight misfire..wtf. The next thing they are telling me is to replace the CAS. I would really like some more information on this. How would I be able to test if its bad? They tried telling me $450 for the part with another $50 in labor..time to pick up the car. Anyone have an extra one laying around?
#58
Couple thoughts...
Check a wiring diagram and make sure your injectors and coil packs are wired to the right cylinders. One boneheaded mechanic wired my injectors wrong, then a much smarter one diagnosed this as the problem.
There are two connectors at the back of the plenum that can be mixed up and cause problems. The VTC and something else (someone else chime in on details). As far as I know it won't throw a code though.
#60
Bump..anyone?
#62
#63
What I'm seeing is a lot of misdiagnosing and people having you just throw parts at the issue hoping to fix it. So lots of "wasted" money on parts and way too high of labor prices. I say wasted as the parts didnt fix the issue, but the one good thing is you have lots of new parts now that will help narrow the issue down. But it also goes back to if they installed said parts correctly. $50 to swap out a CAS is a total ripoff. And I have an extra I can try if I think thats the issue once I look it over. I answered your post over on TT.Net (thats how I found this one) and sent you an email. Lets get the car over to me and get it fixed already .
#64
problem with no power and bad idle I had the same problem
When I first got my 1990 300zx N/A I had the same problem try unplugging the heat censor on top of the thermostat housing, their should be 2 of them one sends the temp to you on your temp gauge in the car (not the one you wanna unplug) the other goes to the computer unplug that one if that one unplugged helps your car run better you need to replace it. it takes 2 sec's it worth a try =]
#65
Main issue was a bad/worn out CAS. There are a few other minor things I'm looking at but swapping out the CAS fixed the main issue the car was having. I had a used one and threw it in. Only took about 15 min to find and fix it.
houlis1211
01-26-2013 03:47 PM
isaacb
09-17-2009 02:59 PM
g35mr2
Northeast Region
06-03-2005 06:09 AM
giZmo
09-16-2002 03:45 PM
