No throttle responce
Old 09-19-2011 | 09:43 AM
TELOZ32's Avatar
Hey guys im new to z world just purchased my first 32 2+2 about a month ago. I have 2 issues or it could b one in the same first my front calipers seem to b sticking randomlly i can put it in neutral nd it wont roll for long or when i try to move i gotta tap the acc allil for it to budge nd i hear the creekin noise as iff i had my foot on the brakes so should i just put new orings in em or is it a diff issue like lines, nd my pedal sinks but i have no leak i have pedal if im goin in the cittty where i got no real speed goin but coming to a long stop i loose em it goes str8 to the floor i pump it nd it starts slowin down but idk if thats the same concern with the calipers..///second it happend 2 times so far I tried steppin on the gas nd i haddd no response it was moving but slowwwwww until it got to like 50 it started pickin up i was in 3rd i went down to 2nd but nuthing so if anyone has any ideas i would gladly appreciate
Old 09-19-2011 | 09:52 AM
Complete 120k mile service kit there is no receipt for it being done in the pat 4 years, bleed the brake system, adjust/replace the ebrake shoes. As for doing it all there are more then enough sites with write ups, jut google it. if your brakes continue to suck, replace the M/C and rebuild the calipers.
Old 09-19-2011 | 12:09 PM
TELOZ32's Avatar
I replaced the rear pads shoes i kno i need to change the fronts are good i bleed em when i changed the rears i drove it home no issue until acouple days i drove it again nd it happend what should i include in the service besides air fuel plugs i put some bg maintenace stuf in the fuel nd the oil.
Old 09-19-2011 | 01:04 PM
The 120k timing belt kit. timing belt, plugs, water pump, cam and crank seals, idler and tensioner, idler studs, crank sprocket, accessory belts..etc courtesyparts.com
As for brakes, make sure a bleeder didn't come loose. Also before anyone complains, please use complete words and grammar. I'm having one helluva time trying to figure out what you are saying.
Gear
03-02-2010 04:32 AM
93300zx
02-09-2010 11:31 AM
Toyota Tank
05-01-2006 01:58 PM
brad101010
11-19-2005 06:40 PM
CWHammer
07-22-2004 10:56 PM
