Please, Please read on ...I need HELP ASAP!!!
Old 12-17-2006 | 03:12 PM
harissanja's Avatar
I own 1990 300ZX N/A and I just had my clutch replaced when I went to pick up the car fro shop I started and something started smoking under the dash, I disconnected the battery and checked the wiring didn't find anything, I also checked all the fuses and under the hood I found the fuse missing (next to the battery Ign Skid Cont) but instead the fuse somebody put the screw so it would make a contact, I pulled the screw out (it was hot) I put new fuse 30A try to start the car but no luck I replaced the ECU thinking that when it was short it fryed the ECU, I just install the used working ECU steel no power I don't get any power to cluster, I can turn the lights on and my seat is working and Security light is blinkig, any idea would be highly appreciated...
I don't have power on windows but power doors are working, could it be security module burned out?
Old 12-17-2006 | 08:12 PM
emo236's Avatar
confuzed member
why are you even dealing with it? Demand that the shop that replaced the clutch fix it.
Old 12-17-2006 | 09:28 PM
harissanja's Avatar
It's because Imy car was stolen few weeks ago and wo ever stole't put that srew
there not the shop, so they did their job and now tis is on me... I just ordered theft warning module I hope that will solve the problem, do you know where does that wire leads because I took my dash completely off hoping I would find frayed wire or something... Any idea at all would be helpful. Thank You and everybody else who replay's in advance!!! :s-redeemer:
Old 12-17-2006 | 10:29 PM
91zxtt's Avatar
EMO's right....you dropped it off at the shop and everything worked fine. You picked it up and things started smoking. The shop clearly did something that caused this problem.
You're wasting your $ by just replacing parts without diagnosing anything. Until you actually figure out what is wrong, don't replace anything else.
The shop likely pinched a wire when they re-assembled the shift touret.
raythenegr0
04-22-2008 07:13 AM
mesallem
01-19-2006 02:56 PM
jabedini
09-30-2002 02:40 PM
