power steering
Old 10-28-2008 | 12:11 PM
  #26
rtmorgan's Avatar
Obsessive Craigslist Disorder
yeah well i took th car down there and they flushed the entire system and put in atf it is better but not like it should be.
wowever over the past month or so every once in a while my power steering will work and have actual power but it vary how long it lasts. so im thinking i may have a sticky pressure relief valve. so i will probally rebiuld the pump and put in a new valve. what do you guys think?
and yes zlover you are very true on that one shouldnt take there car to a full service car wash ill never let my dad take my car again to get work done lol
Old 10-28-2008 | 02:14 PM
  #27
i say replace it with a good pump instead of rebuilding it yourself. nissan oem or try napa. dont go to cheap though or it probably wont last long
Old 10-28-2008 | 02:21 PM
  #28
KasbeKZ's Avatar
Pr0n Addict
true that on the new pump. mine is doing the same thing as yours, zloversaid his did the same thing when his got ps fluid in it, it can't be fixed, just get a new pump. i'm thinking about just getting a new face though. it's not really a rebuild, just replacing the internals i guess.
Old 10-28-2008 | 02:26 PM
  #29
rtmorgan's Avatar
yeah if i can afford a new pump i will get one but i have to come up with 185 for my ticket so a pump rebuild i will most likely try first
Old 10-28-2008 | 02:40 PM
  #30
KasbeKZ's Avatar
Pr0n Addict
i know what you mean, but you may end up wasting some money on the parts for that rebuild.
Old 10-28-2008 | 03:30 PM
  #31
rtmorgan's Avatar
i dont even think the pump itself is bad i think the pressure release valve is just stuck and not letting the pump build pressure.
Old 10-28-2008 | 05:19 PM
  #32
KasbeKZ's Avatar
Pr0n Addict
you can try, but is it really likely that putting an inadequate lubricant in the pump caused the pressure release valve to stick, or is it more likely that the inadequate lubrication caused major damage of the more vital and more dependent on lubrication parts?
Old 10-28-2008 | 05:25 PM
  #33
ZLover4Life's Avatar
Encyclopedic Knowledge
I agree, but if he wants to try rebuilding it, let him. It's not expensive to rebuild and if it does end up working, he saved a lot of money.
Old 10-28-2008 | 05:57 PM
  #34
rtmorgan's Avatar
yeah zlover i figured for 20 bucks i could at least try to rebuild it if it works then i save what like 140 ish?
if it doesnt work i wasted 20 bucks? ehh i have wasted more on worse things than that
Old 10-28-2008 | 06:06 PM
  #35
Money is almost never wasted. Often times, when it seems wasted, it comes with a lesson (whether it be learning a new skill or a moral lesson). In this case, you will gain intimate knowledge of the inner workings of the Z32's power steering pump. $20 to learn the mechanics of the PS pump is a fair trade, if you ask me.
On the other hand, people who blow money on cheap parts learn that it's a dumb decision... so I'd consider your potentially "wasted" money to be much more valuable than that of someone who bought something like an Apollo intercooler. The only lesson they learn is that they should've stuck with the facts... and it takes them much longer to realize their lesson. LOL
Old 10-28-2008 | 06:28 PM
  #36
Ratfink's Avatar
Hoov for Pres!
Words of wisdom.
  #37
rtmorgan's Avatar
lol that is very true
Old 10-28-2008 | 07:23 PM
  #38
KasbeKZ's Avatar
Pr0n Addict
yeah that's a good point. i wasn't aware of the cost of the rebuild kit when i made my statements. let me know how the rebuild goes. i may be following suit
Old 12-05-2008 | 05:14 PM
  #39
KasbeKZ's Avatar
Pr0n Addict
so where is the text that states that ps fluid isn't an adequate lubricant for the Z32? this guy at the z shop keeps saying that it shouldn't ruin the pump. i'm just trying to show him cause he wants to argue about it.
Old 12-05-2008 | 06:04 PM
  #40
rtmorgan's Avatar
what are you talking about?
it says in the owners manual and online one to only use atf
i should have read it but ohh well
Old 12-05-2008 | 06:31 PM
  #41
Ratfink's Avatar
Hoov for Pres!
Yeah.. You should have. Hopefully you have ATF in yours right now. Or look at replacing it.
Old 12-05-2008 | 07:02 PM
  #42
KasbeKZ's Avatar
Pr0n Addict
yeah i know it says it's supposed to use ATF, but i'm looking for the text that says "ps fluid is not adequate lubrication for the z32. it will ruin the pump". i know it's true, i'm just looking for a reference to prove it
Old 12-05-2008 | 07:32 PM
  #43
tell him if he is so sure about it fill his pump with PS fluid (assuming he has a Z32) and prove you wrong. other wise tell him to go S a D
Old 12-05-2008 | 08:50 PM
  #44
KasbeKZ's Avatar
Pr0n Addict
lol you would think that would work. but i told him the ps fluid ruined my pump, and he said it must have been a coincidence. that's why i'm looking for text proof
Old 12-05-2008 | 08:54 PM
  #45
rtmorgan's Avatar
shouldnt nissan be able to confirm that only atf should be run?
if not tell him to call either conceptz, z1 etc. if he is that stubborn then f*** him.
tell him to look at the color of the fluid in it now ps fluid is *** color if i recall correctly
and atf is red
Old 12-05-2008 | 09:13 PM
  #46
KasbeKZ's Avatar
Pr0n Addict
ps fluid i've seen looks like water
Old 12-06-2008 | 02:54 PM
  #47
What the f*ck shop are you going to?? There is recommended fluid for a reason. That's like putting gear lube in the engine and saying "show me where it says that using anything other than motor oil will ruin the engine." It shouldn't need to be explicitly stated to be obvious.
Old 12-06-2008 | 03:00 PM
  #48
a lawyer would say differently, when reading FAR's for flight they restate EVERYTHING and leave no room for questions like this. written by lawyers so retards cant do something illegal and then go, "well, it didn't say i necessarily COULDN'T" it's ridiculous reading some of the crap in that book makes you feel like a 2 year old
Old 12-06-2008 | 04:53 PM
  #49
KasbeKZ's Avatar
Pr0n Addict
yeah that's what i thought. but this guy's all "certified" on z cars and ****. he goes to seminars in japan and classes for z technicians and stuff. he thinks he knows all and there have been several times now that i just wanted to say no. you're wrong.
Old 12-06-2008 | 05:27 PM
  #50
Ratfink's Avatar
Hoov for Pres!
Tell him to quit going to Japan, and spend some time on here with us.
We'll go easy on him.
People that think they know everything are the ones that most definitely do not.
He may know a lot about Z cars. But he should never think he knows everything.
Humans are all fallible.
