power steering
#82
ok i will make this simple, the power steering system is a hydraulic system, now the z32 auto trans is a mix of hydraulic and electrical, now the only problem i see with running ATF in your P/S system is all of the detergents in it could possibly cause some leaks and i would not recommend it as being a permanent replacement, although i have successfully gone over 100k miles on ATF in the P/S system the long term results include a worn rack and pinion or steering box and a worn out pump. now see with P/S fluid it carry's more lubrication and less detergents and will last alot longer at max line pressure and well is just pretty much designed to be ignored, abused and forgotten, where as ATF doesnt like to be ignored and abused and doesnt like heat very much, where as P/S fluid can get way hotter then ATF and be fine.
shall345
01-04-2004 04:10 PM
