Restoring a z32
Restoring a z32
I have a 91TT rolling chassis that i want to completely redo
I will need info and help putting a new main harness, fuse box ,and relays back under the hood.
has anyone here taken a 300zx chassis and restored it to a complete running car?
If anyone has any pictures of the fuse box and wiring harness with the engine out of the the car that could give me a clue of where to start.
Im located in austin tx so if there are any local guys or Z shops around? any help would be greatly appriciated.
One last thing is the fuse box integrated with the main harness or do I have to install it wire by wire?
These cars were as much as $40k plus new. I hope you have deeper pockets if you want to restore one. You could likely buy one in immaculate shape and low Kms for wayyyyy cheaper.
Or knock yourself out and good luck. What kind of job do you have?
Originally Posted by bowerboy_1
Does the fuse box have a connection so that I can connect it to the main wiring harness?
Where can I buy an ecu from?
Does anybody know af a reputable company where I can buy a front clip from?
-Juanton
I would like to see pics
are the harnesses on the TT the same as the ones on the na Z's?
Try Ebay.I most don't like it but its going be your best bet to restore your car for cheap.
z4u2nv
05-22-2012 10:47 PM
