Squealing fan clutch
I developed a realliy bad squeal at high rpms. After several hours I have it narrowed down to the fan clutch, but cant find anything on squealing fan? Anyone heard of an OEM Fan doing this?
But is the belt TIGHT enough? A classic sign that the belt isn't tight enough is a squeal @ start up...
Belts are tight and new, have replaced everything else. I am going to pull the fan off and see if it goes away only thing I have left to do. I pulled both belts, one at a time nd it still squeals.
I tightened the belt a ton past the point it should be compared my other cars. Unless the belt on the water pump is supposed to be tighter than belts normally would be. plus sometimes when i down shift it can just chirp a little.
Bravenewme
11-18-2014 01:22 PM
jaromgi
12-18-2011 04:35 PM
