Timing belt change
Timing belt change
I'm taking my car in to the shop for a timing belt change, reason being is I don't know the last time it was changed or if it has ever been changed, I have a 1990 300z Na, my mechanic is going to change the belt water pump thermostat and check pullys hoses and radiator rust, is there a specific timing belt that I should request from him? Should I see some increase in power? Anything else I should ask him to do or check while he is in there? My mechanic works on a lot of z's pons mechanic shop in Miami he seems pretty knowledgable with these cars but I guess the more info I get the better choices I make.
Thanks again guys, this forum is great, keep up the good work
Nissan
Nissan parts all the way. If he can't get them for you, order them from someone like Timing Belt Kits :: Maintenance :: 300ZX Parts (Z32) 1990-1996 :: Nissan Parts, NISMO and Nissan Accessories - Courtesyparts.com, get the kit, it will have everything you will need.
Wow hey predator thanks a lot man I didn't even know this existed, very much appreciated, now I need to contact my mechanic early and let him know that this is what I want,
Thanks again,
Btw how much do you think it would run me for the installation of all these parts?
Thanks again,
Lots
From a quick search, you will be looking at between 500 to 700 labor, thats calculating 8+ hours at an average $85 an hour. Having said that, its a fairly strait forward job, you could do it yourself. If the cost isn't an issue, and you really don't want to tackle it yourself then its all good. If you have a decent set of tools and a place you can work, get a manual, or download the FSM XenonZ32.com Reference and give yourself a weekend. A lot of satisfaction can be had wrenching your own car. You might also be able to find a someone local in the forums who could help with the install. Either way, good luck
Thank you again
Frodz
01-01-2012 10:04 AM
CanyonCarver
12
05-16-2005 01:57 PM
