White smoke coming out exhaust
Well recently it has seemed that my car has excessive white smoke at idle. It has true dual exhaust all the way back and the white smoke is coming out of both sides of the exhaust. The car does not do it at first when you start it up but about 30 seconds or so after start up. Also it starts missing aswell. I did drive it up the road and back and it stopped missing but it has still smoked after it was warm before. Thought it may be head gaskets but the car has a bad heater core so I assume if I pressure test it the heater core will start leaking. Also the water in the radiator was a brownish color.
Brownish coolant probably just means rust... flush it out.
Compression test can diagnose bad head gasket... does sound like thatcould be your problem. White smoke is generally coolant. TT or NA?
myfairlady
07-16-2008 01:48 PM
