02 maxima engine(vq30) convert to 300zx(vg30)
Old 11-13-2007 | 08:57 AM
nikitenko91's Avatar
i have a 92 300zx with a bad motor and i have a 02 v6 3.0 maxima engine laying around (vq30) so read on a website http://z31.com/repairs/newengine.shtml how to convert a maxima engine into a 300zx engine but on the website the guy used a 88 maxima motor and i think he used a z31 300zx. but i got a new maxima motor and a z32 300zx so i was wondering if it will work the same and if i can convert it.
Old 11-13-2007 | 09:12 AM
Just depends if the Maxima motor can be mounted frontward instead of sideways. You'll need to check the clearances, and see where the motor mounts will sit. You will also need the VQ engine harness and ecu, and both wiring harnesses to see which wires will need to be spliced / tapped.
Remember: ANYTHING IS POSSIBLE, IF YOU HAVE ENOUGH $$$. Be realistic tho... why not sell the VQ motor and buy a VG30DE motor??? That would save you A LOT of time and headaches.
Old 11-13-2007 | 10:33 AM
bardabe's Avatar
Bad Speller
It's been done in the S-Chassis before, he will need a Z33 Upper and Lower Oil Pan. + Custom motor mounts. and a Z33 Tranny.
Enjoy
Old 11-13-2007 | 10:36 AM
if i do what it says on that website that i posted will it work?
Old 11-13-2007 | 11:17 AM
entropy31's Avatar
The Cake Is A Lie!
no. totally different. '02 maxima engine is a VQ, the z has a VG. and a z31 and z32 are totally different cars. and the VG30s in a z31 and a z32 are very different engines.
Old 11-13-2007 | 11:22 AM
ok thanks thread closed.
Old 11-13-2007 | 09:22 PM
91zxtt's Avatar
Well, sort of...the blocks are the same, but that's about it. You're mostly right.
Old 11-14-2007 | 05:55 AM
thats what i need is the block. ill take a look at the engine cuz i got both of the engines at home but i dont know if the zx heads will bolt on to the vq block.
Old 11-14-2007 | 08:00 AM
convert the Z32 to FWD!
Old 11-14-2007 | 08:22 AM
entropy31's Avatar
The Cake Is A Lie!
yes, i am well aware of that, which is why i said "very different" rather than "completely different". i didn't feel the need to confuse matters, for reasons that are obvious below.
he was talking about the VG30E and the VG30DE. yes, they share the same basic block, but not much else. the VQ is a totally different block. it's also aluminum, whereas the VG blocks are iron. find a VG30DE. that is what you need.
and btw, '02 and up Maximas had the VQ35, not the VQ30.
Old 11-14-2007 | 08:48 AM
if the blocks were the same on the VG-E and DE wouldnt people be swaping the heads all day long into their Z31? or at least having alot of easy swaping the DE into their Z31?
Old 11-14-2007 | 08:49 AM
entropy31's Avatar
The Cake Is A Lie!
they are not 100% the same. just the same basic block design. and wtf is "having a lot of easy"?
Old 11-14-2007 | 08:58 AM
unmmmmm... replace easy with people, and thats what i meant. and what you just said makes them different block designs. different oil/water pasages, mounting points... thats a different block design. they might be based on teh same concept being iron and a 3 litre V6.... but different blocks then. you guys lie
Old 11-14-2007 | 09:35 AM
What he should do is sell both V6 engines and buy a RWD VQ35HR from a 2007 350Z. 306hp (265whp)
Old 11-14-2007 | 10:17 AM
bardabe's Avatar
Bad Speller
then he might as well cough up a few more G;s and get the VQ37HR from the 2008 GTR but that's just me thinking
Old 11-14-2007 | 01:49 PM
oh, so true. Is that the same engine as the G37? 330hp?
Old 11-14-2007 | 03:24 PM
i dont wont an engine swap i just thought that the vq30de fits into a 300zx.
Old 11-14-2007 | 03:26 PM
Wouldn't swapping in a VQ30 be an engine swap?
Old 11-14-2007 | 08:50 PM
bardabe's Avatar
Bad Speller
G37 = N/A 330hp
GTR = TT 500BHP
Old 11-15-2007 | 04:30 AM
i thought that the block from vq30de fits right into 300zx and uses same engine mounts.
Old 11-15-2007 | 07:49 AM
entropy31's Avatar
The Cake Is A Lie!
nope. it does not. and if you have an '02 Maxima, it has a VQ35.
Old 11-15-2007 | 05:03 PM
KasbeKZ's Avatar
Pr0n Addict
rebuilt or used 300 blocks arn't always that much. you could pick up a complete 50K Z32 engine for about $1000. maybe 2000 give or take for the whole job if you skimp a little.
Niku-Sama
05-26-2010 05:13 PM
turboZ87.300
11-08-2007 10:00 PM
nickgold
04-22-2007 03:18 AM
killermonkeys
07-22-2001 05:56 PM
Quick Reply: 02 maxima engine(vq30) convert to 300zx(vg30)
