120k service advice
Old 03-31-2004 | 11:46 AM
91zxtt's Avatar
The idler pulleys are recommended to be replaced at 120k. I did mine at 145k. They looked fine, but you never know for sure. Go with kit 2. I'm personally not a big fan of waterpump gaskets. If you don't get it tightenend down just right, they can leak. You can get a silicone based gasket material at any local auto parts store. Other than that, it looks good.
Old 03-31-2004 | 05:43 PM
Riz Z Speed's Avatar
Administrative Brown Guy
pcv valves themselves would be good. Fuel filter if not already done. Clean your air filter. Change the oil. You'll need coolant/antifreeze since you'll need to drain the radiator. Distilled water to mix it with. You'll also need a pulley puller tool to remove the pulleys.
Old 04-01-2004 | 07:18 AM
silvrhand's Avatar
Snazzy Title
O2 sensors might be a good idea as well if they haven't been replaced.
Old 04-05-2004 | 04:55 PM
91zxtt's Avatar
Hey, just for fun, why don't you buy the ASHSPEC ECU. Check out z1motorsports.com. You don't need it for the 120k service, but since you're doing all this maintenance stuff, why not add a performance mod to make it a little more fun.
Old 04-06-2004 | 12:14 PM
91zxtt's Avatar
Nah, it's $600, but you $300 back when you return the core, so it only costs you $300. The chip gives you more horsepower and torque than the exhaust manifold will, plus for less time and $.
Old 04-06-2004 | 01:22 PM
If you don't mind having your car down for a little while, you can send in your ecu. That way you'll avoid the core charge. If you pay for the overnight shipping both ways, you'll get it sooner.
Old 04-06-2004 | 01:30 PM
That's why I suggested the overnight shipping.
You'd be out a car 3 maybe 4 days at most.
Call Z1 and find out.
Old 04-06-2004 | 02:37 PM
91zxtt's Avatar
Thank you for the compliments. I've been meaning to get some pictures of my Z on here, but haven't had the time. I don't know about going with no-mufflers. The turbos absorb a lot of the exhaust sounds, but without mufflers at all it'd probably be too loud. Plus, there would be minimal gains in performance by removing the mufflers.
jerome2021
10-19-2013 07:43 PM
KinkyJoker
01-26-2012 08:01 AM
importracr2639
02-08-2006 01:18 PM
dgtl_rebellion
07-26-2005 06:50 AM
pearly whites
09-01-2004 03:21 PM
