1991 300ZXTT Electric Fan and Exhaust
I recently purchased a 1991 300ZX Twin Turbo 5 Speed in rough condition. It has problems over heating and I am currently changing out the parts that have obviously gone bad. One of my questions is about Electric fans in regards to what kinds I should look into (preferably with built in thermostat and possibly a resemblance of a fan shroud) with maybe some consideration into costs. I was reading other posts about just keeping the clutch fan however the posts were all for N/A's and it stated that they have a lot of suction power which could be bad in dusty areas (I live in Phoenix).
Also I was looking into purchasing a Specialty Z exhaust, I like the sound and appearance a little more then the HKS although I still may consider changing my mind. I was wondering however for the Twin Turbo if a 3" full exhaust would be the most beneficial for the current output, I intend on doing performance mods but potentially not for awhile depending on my budget.
Any input will be greatly appreciated.
https://www.zdriver.com/forums/showt...t=electric+fan
Read that.. I'd go with the stock fan. But if you are stuck on electric then it's got info in there about it also..
If its overheating theres a reason for it, find the problem and fix it, dont band aid it. also it has been proven countless times that an electric fan on a z32 thats going to be driven hard wont cut it, unless you get something into the 3500+ CFM fans, with a sealed air box and sealed fan shroud.
hondakilla
09-28-2004 04:57 PM
