300zx exhaust question
no. 2+2 and 2 seater exhausts are not interchangable.
Aside from that, because of the gas tank, 2+2 exhaust systems are generally VERY restrictive... for your Twin Turbo, get an exhaust that makes more power (which is the only good reason for an aftermarket exhaust), such as Spectialty Z or HKS Hi-Power.
Only problem is that the HKS Hyper DOES NOT bolt up to the 2+2...again the gas tank interfers.
Nothing on the exhaust is interchangable between a TT and 2+2. The midpipes/ test pipes are the wrong length. You will have to order JDM midpipes/ test pipes from Japan. Or see if someone like Z1 makes them for their conversions.
... which is why I recommended it for his TT (he was asking about exhausts to put on his TT... if he could swap the one from his 2+2 over)
Originally Posted by Mousier158
Wrong . test/mid pipes are the same length 2+2 or 2 seater here in Japan .
So, while nissanracer can't swap his whole exhaust, he can swap from the axel back.
