90 tt brake shake
Guest
Posts: n/a
90 tt brake shake
Upon moderate to highway speed braking car vibrates in wheel & pedal...on smooth roads barley nothing rough rutted buckle up...just did skins, rotors & pads...inner LR tie rod little loose..no leaks or fluid loss...ABS light on...would sensor failing cause calipers to open -shut? Cool real life x files am radio/site. artbell.com unknowncountry.com S
Guest
Posts: n/a
Re: 90 tt brake shake
Your tires might need to be balanced, and/or rotated. If thats not the case I have read somewhere that there are tight specs when milling the 300ZX rotors, and that when it is done, It needs to be done when the rotors are on the vehicle. Talk with a certified Z mechanic, see what he thinks.
Adam
1996 300Z TT
Adam
1996 300Z TT
KasbeKZ
26
02-21-2009 08:41 PM
