'91 300zx TT, push clutch in, car won't go into gear
Old 10-13-2009 | 10:33 AM
w8lifter21's Avatar
I jumped in my car last night heading home from work. Noticed that it was extremely difficult to get the car into first, then a little easier into 2nd, etc. Figured it was due to the cold.(~45 deg.) I noticed while driving home last night that the clutch felt different. Pedal still has full travel, but seems to me completely disengaged only about 1" off the floor.
Jump in the car this morning (~55deg), fire it up, let it warm up for a min. Push clutch in, car won't go into any gear. Nothing grinds as I try to put it in gear, but I can feel the car lurch ever so slightly. Shifter moves freely left and right, I just can't push it into any gear.
A little more background. The past few months, the clutch pedal would "change feeling". Sometimes when I would drive, it would be a little more firm than other times. Sometimes, a little less firm than average. Now, I'm not talking huge differences that would greatly affect or change the way I would have to drive, but it is definitely noticeable. Maybe there is a clutch adjustment that needs to be made?
Car is a '91 300zx TT, ~100k, daily driver while the weather is nice.
Old 10-13-2009 | 12:54 PM
ZLover4Life's Avatar
Encyclopedic Knowledge
Check for leaks/problems in the clutch hydraulics... likely a bad slave cylinder (cheap to replace, only about $25 at any auto parts store). Refill fluid, bleed, done.
Old 10-14-2009 | 06:38 PM
w8lifter21's Avatar
Thanks for the info., i'll start there. ChicagoZ.com FTW!
Old 10-14-2009 | 08:49 PM
nismo613's Avatar
2nd the slave
Old 10-26-2009 | 05:08 PM
luv_twins's Avatar
could be slave or master, pull boot back on slave if fluid leaks out the slave is bypassing, if there is brake fluid running down your firewall its the master.
Old 10-26-2009 | 08:50 PM
... he hasn't responded in a week and a half... I'd then suspect the problem was resolved and was the slave cylinder as I suggested
Old 10-27-2009 | 12:42 AM
luv_twins's Avatar
sorry never really paid attention, i was at th very top so i kinda assumed it was recent, these forums must be dead then....
Old 10-27-2009 | 10:16 AM
KasbeKZ's Avatar
Pr0n Addict
for the record a new place for a leak that i've recently found is where the hose goes through a bracket that has insulation in it, mounted to the passenger side firewall. the insulation holds moisture and rusts the hose, and it blows a leak. happened to me a few weeks ago.
perfectindustry
08-16-2016 07:41 PM
Carson B
06-01-2014 05:25 PM
Fairlady92zx
06-30-2011 05:03 PM
Z'sOwnTheRoad
03-16-2007 07:42 AM
justinmy300z
14
01-29-2006 03:06 PM
Quick Reply: '91 300zx TT, push clutch in, car won't go into gear
