91' cold running issue under load
Old 11-04-2007 | 04:31 PM
dcshd's Avatar
car runs fine after reaching operating temp. not very drivable cold--very bad when shifting 1-2 gear Any thoughts? Just had all new injectors and injector plugs replaced- egr passages cleaned out.
Old 11-04-2007 | 06:27 PM
KasbeKZ's Avatar
Pr0n Addict
check the basics like Otiny2 sensors and temerature sending units
Old 11-04-2007 | 06:28 PM
KasbeKZ's Avatar
Pr0n Addict
check the basics like Otiny2 sensors and temerature sending units. an ECU diagnostic is the first thing i would do
Old 11-04-2007 | 06:34 PM
dcshd's Avatar
would slow o2's give this type of problem and go away with engine temp. ?coolant temp sensor reads good.
Old 11-04-2007 | 08:17 PM
b300z's Avatar
caught the z fever
please check search first for a question like this. heres a thread with plenty of information concerning a poorly running Z. https://www.zdriver.com/forums/showt...ight=high+idle
also, we need more details to fully help you. is this just an engine problem, or are you having trouble shifting as well?
Old 11-05-2007 | 06:25 AM
dcshd's Avatar
Not a shifting problem. car only has a problem when cold---first 5-7 min. of driving then all of a sudden runs great. Initially when pullig out in first gear its not bad but as soon as you shift to second gear and let the clutch out it falls flat on its face and it does not matter how much your on the throttle. It takes a few seconds before it starts to accelerate at all. This also happens second-third gear shift but not as drastic. Any thoughts?
Old 11-05-2007 | 08:24 AM
cake872's Avatar
I could be rong but jus putting it out there. What size fuel injectors did u install. If there a big step up and your fuel pump isnt giving enough preasure then i think it can be a problem.
Old 11-05-2007 | 08:32 AM
b300z's Avatar
caught the z fever
Originally Posted by dcshd
Any thoughts?
read thru the thread i gave you
Old 11-05-2007 | 06:12 PM
dcshd's Avatar
thanks everyone for your help. turned out to be o2 heater bad
Gonzo
05-01-2013 03:27 AM
pa312d
12-09-2012 11:12 AM
Joncampbe
09-04-2012 09:10 AM
richlkyl000
11-19-2011 12:06 PM
Cavinder
04-16-2010 03:04 PM
