adjustable cam gears
Originally Posted by emo236
not much, I'd get your car working right before moding anymore if I were you. Just a suggestion.
Uh, yea...1st things first....get the car running 1st.
I bet the adjustable Cam gears will give you another 50 HP with that Hydro power monster you're building.
you need an ECU.
That doesn't make any sense. The cars run rich when they're cold, not lean. The problem you're describing likely isn't a fuel issue. If you're actually going to run NOS and do all of the mods you talk about doing, then you'll likely need the larger injectors. A nearly stock N/A has no need for larger injectors. You will not see any change in the power with this mod if your car is virtually stock.
