annyone know how to resset there stock ecu????
Old 01-25-2008 | 01:28 PM
preprodigy's Avatar
hey whats up, i own a 90 Z32 N/A.
i'm replacing my fuel injectors and want to resset my ecu after i'm finished, how is this done? i've searched around but couldn't find anything.
is it just unhooking the battery for a certian period of time..
or is there ore to it?
thanks
Old 01-25-2008 | 01:47 PM
Reset it for what? Why would you need to reset the ecu?
Old 01-25-2008 | 01:57 PM
preprodigy's Avatar
i was told that if the car has been running shity for a while the ecu will remap to run as good as it can in the condition its in, and whe you fix the problem you need to resset the ecu. now this is what i was told by a master technician from nissan. weather or no this is the case.. i dont know.
but better safe then sorry.
do you know how?
Old 01-25-2008 | 02:04 PM
KasbeKZ's Avatar
Pr0n Addict
sometimes disconnecting the battery for a while will help. i'm not sure if that does any re-setting or anything though.
Old 01-25-2008 | 02:11 PM
Ah... you didn't say it was running bad in your first post.
Have you checked the Z32 FAQ's / Gen Info page? https://www.zdriver.com/forums/300zx-z32-tech-tips-273/general-z32-info-8434/
And by doing a quick ZDriver / Google search: https://www.zdriver.com/forums/350z-z33-forums-6/anyone-really-know-8838/
Originally Posted by 91zxtt
It's always a good idea to reset the ECU after installing a MOD. Generally, when you're working on anything electronic in your car, you're 'supposed' to disconnect the battery. I'm guilty of not always doing it. Some have noticed their car runs poorly after installing a MOD when they don't reset the ECU, but notice an improvement after doing so. What you want to do is leave the battery disconnected for 10 minutes, or so. After you reconnect it, take the car out and really hammer the throttle. Take it to redline, or close, in the 1st 3 gears. This will help the ECU recalibrate the air/fuel mixture, which helps it run better.
Old 01-25-2008 | 02:19 PM
ZLover4Life's Avatar
Encyclopedic Knowledge
You can't "resset" something that was never "sset" in the first place.
If it was once set, you would want to reset it.
Disconnect the battery for about 15 minutes.
Old 01-25-2008 | 02:27 PM
preprodigy's Avatar
so if i disconnect the battery for 15 mins, and pump the brakes to drain any remaining power. this will set the ecu?
then i wont have to do anything else???
Old 01-25-2008 | 02:29 PM
why would pumping the brakes do anything if the battery is disconnected? whats even wrong with the car other than the injectors? does it run like *** or something? throwing codes? check engine light? just get the new injectors installed then disconnect the batter for 15 minutes (go get lunch) then start it and hope for the best.
Old 01-25-2008 | 02:30 PM
Drain the power? WTF???
Old 01-25-2008 | 03:47 PM
It is clear to me that you have no electrical background. As such, I'm going to have to recommend that you take your car to a shop.
Old 01-25-2008 | 05:28 PM
MikeZ's Avatar
So your telling me that pumping the brakes doesn't reset the ECU?!?!??! Dammit, my uncle kliedis was wrong after all. lol
Old 01-25-2008 | 08:36 PM
KasbeKZ's Avatar
Pr0n Addict
haha. you said kliedis.
Old 01-25-2008 | 08:48 PM
SpeciallySpiked's Avatar
I'm a Registered User!
I'm guessing he meant pressing the brakes to discharge any remaining electricity through his brake lights.
However, I do not believe that would do anything to the small moment of electricity left in his ECU....
Then again, that's why they say wait 15 minutes...
So kid, just do as they say, don't add on "should I also turn on my windshield wipers while standing on one leg and touching my nose?"
Old 01-25-2008 | 08:58 PM
Since I feel like being very clear and thorough right now, I'll explain why it was a dumb question.
Voltage is pressure. If you remove a battery while the car is not running, you remove the voltage (pressure) source. If there's no voltage (pressure) pushing electrons through the system (current), then there's no power (power is a flow of electrons), thus the brake lights couldn't even flicker. The ECU does have the ability to maintain some power for a short while (same technology as most modern aftermarket car stereos and boost controllers), but it is seperate from the rest of the elctrical system (not connected in any way to your brake lights). Leave the battery disconnected long enough and this charge will dissipate, thus clearing the ECU's memory.
Old 01-25-2008 | 09:05 PM
KasbeKZ's Avatar
Pr0n Addict
interesting lesson about voltage. i've been trying to get educated on the topic of electicity. maybe we'll touch on it in mech. eng. school!
Old 01-25-2008 | 10:38 PM
unless you have a capacitor or another method of storing the energy from the battery when the circuit was complete. but obviously a Z wouldnt have that.
Old 01-26-2008 | 12:45 AM
Capacitors are only good for real short bursts of electricity - that's what makes them different from batteries. The very large ones used in car stereo systems are simply to prevent dimming of the dash and headlights during hard bass thumps that drain a lot of system energy for only a split second. So, yes, if you had a very large capacitor on the electrical system, disconnected the battery and stepped on the brakes, they'd flash and then go out. But I don't know of any car that has a setup like that other than in the stereo (and I can't think of any practical use for it either).
MikerZ
12-03-2013 12:18 PM
SandW
10-31-2006 10:26 PM
RaCeRzX
10-15-2002 09:11 PM
