arrrrghhhhh!!!!!! #&%$*@ing water pump
yippee, coolant puddle. pull off the plastic shield, and its dripping off the crank pulley. whats right above that??? you guessed it . i hate dropping it off somewhere, but with my new job, i hardly have time to get into it, out of town too much. i read the writeup, doesnt look too bad, but the time thing...... tough decision.
you know what, screw it. i think i will just take it in and have the whole 60k package done. if its getting taken apart that much, it may as well have all of that stuff done. the previous owner said it was done, but hey, better safe than sorry. i just wish i had the time to do it myself.
well, i think i might have time to do the pump, but not the time to get to the rest of the stuff. havent been able to get ahold of any shops (saturday) and i leave for a week on monday. i read the writeup, and it does not look to be a difficult job, just lots of removing crap. is this something i want to tackle in a limited time schedule? i hear 2 hours if you dont hit any snags. only water pump i have done is on a blazer.
well, got an appointment with the stealership . gonna do the full 60k. i just dont have time to wait for the parts. i have heard they have a good z guy, so fingers crossed. luckily i got to take a company van for the weekend.
you know the z32 motto. "you better have a few grand set aside just in case".
holy $#!^ if my car ever needs more then 1.5k i better have a blown motor, totaled car, dea....because i would be fu**ing screwed if my car would ever needed alot of work..luckily the PO is paying for my 120k service because he didnt do the first 60k..
Queen of Yachts
Location: warmspott, trollville.......somewhere sailing the seas--fla, virgin islands...wherever....warm water....LOL
dog! i'm female, and i have never had to take my car to stealerships--been clued in re: specialty and independents since race work days, and i always fixed my VW's myself--but, even at retail in a specialty shop on my z31, i never paid more than 500$ for that work--i guess they were right--having a z32 is like having a boat--break out another thou-------!
i thought the 60k was only neccessary on the TT and it was a bit more miles until an N/A needed it. where the hell did i read that?
wish i was in san diego, it would be going to z-whizz.
Rod.
well, im at 117k on the original belt and drive it to the limits and back weekly and it hasnt broken YET
~$1k isn't bad at the stealership. I just hope they replace the tensioner, pullies and seals. I'd make sure and get the old parts back when they're done so you will see what they actually replaced.
dude, got a 50 its not your pump...its the hoses conecting it to the flow tubes..they are held on buy those stupid compression clamps, not a hose clamp..the hoses leak out around the alluminnum tubes..mine had corrosion between the rubber and alluminnum causing water to slowly leak out.. most likely from not correct amount of coolant to stop corrosion on alluminnum..
as far as repair time.. i came home from work like 3 days in a row and did it..its as easy as takeing parts off and putting them back on..did have to buy a puller and allen wrenches.. i replased the pump because i bought ALL new parts. they were corroded and was not going to do it again.. i also added a alluminnum crank pully..my point is though that its most likely a leak
damn thing feels like driveing a cruise missle....
I dont know who told u 2 or 3 hours... the first time i did the water pump on my 1993 300zx it took me a half a day just to figure out were and what to take off never the less i got everythign apart.. i sanded and polished the intake and outlet water pipes.. but when i got down to the water pump i ran into a problem there is a sheild that seems to hold everything on.. i gave up.. and put everything back on.. my car doesnt keep good pressure because of water pump small leak... 2 or 3 drips ever few days
Water Pump
yes, the Z 's waterpump is a pain, but you can take one out and put a new one in if you have 4 hours to kill and have done it before. You have to take off the belts, the crank pully, the timing belt covers (nevermind the hoses drain the radiator, remove the radiator, the shroud,the fan and remove the PTU (off to the side). Get a good allen set for your rachet as it will come in handy for the shrouds, the crank will come off pretty easily IF you have done it before and there is no rust...if there is get a 2x4 and place it over the crank and smack the lumber a few times then spray the liquid wrench in the slot where the key is and take your time with the puller, nothing worse then snapping one of those bolts. believe it or not you can, in a pinch use 2 of the longer shroud cover bolts to pull out the crank. if you have a dremel use it to smooth the two pipe fittings that are above the pump and have those silly little hoses attached to them as they do tend to corrode a bit and WILL leak after you put everythign back together if you don't remove the corrosion. That pump will want to stay where it is and you might have to get rough with it to break that hold the RTV has on it but before you do it...make sure that you have all the bolts out of it.
just remember there isn't any shorcuts to doing this job and don't leave the shrouds off cause you think it looks cool cause they do a really good job of keeping oil and dirt and water off the timing belt.
I know all this cause my belt was overtightened and caused my pump to fail after only 7k miles and i have done this job a few times now... I have also done the A/C compressor (removal/install new) and i can do that job in about 1.5 hours complete. But to be honest, once i hit the lotto, ill pay people to bring me cheese and wine while i watch someone else struggle doing these jobs on a car.
