Belt squeal
Belt squeal
Hey guys everytime i start my car up in the morning it has this horrible squal that lasts for about 20 seconds and goes away..its the drive belt..should i spray belt dressing on it????/
thanks
thanks
there's about ~4 inches of adjustment on the alternator it looks like. that belt would have to be WAY too big. check it out though. if it's at max big adjustment, and the belt is still loose, then order a new one.
I have put several belts on mine without resolve. I continue to tighten the belts. Mine is an 88 z. Nissan designed the alternator belt to small therefore can not support the startup load. mine does the same thing untill it warms for about 30 sec. I believe its just something you will live with
