blue smoke out exhaust! Need Help!!!
ok i need some serious help. i have done everything i can think of to fix this smoke problem and now need expert advice. just started smoking about 2mos ago and i just cant figure it out. changed pcv valves, just put in new drain back lines to turbos, new coilpacks, tps, fpr, 6ht plugs, had compression test not long ago that came out good. checked for vacuum leaks, cleaned ic pipping, so yea idk wtf to do more.... please Help?
blue smoke
According to the previous owner the engin was rebuilt 50k miles ago. The turbos were upgraded from t25 to t28 about 9 mos ago. I thought it was the seals on the turbos too but called the company that built them and they said it shouldnt be the turbos, key word (shouldn't ) so yea im at a loss... ive put alot of work into the car and to have this problem really sucks. Any help to pinpoint issue would be great.
Are you running cats, or test pipes? Wondering if on deceleration due to lack of pressure on one side of the impeller, its slightly pushing the seal out and leaking oil by. Have heard of it before.
I meant more the LACK of back-pressure, that is if the seal is going out, but I mean if its new, do you have stock cats, maybe slap them in and see....Could be pulling oil through valve seals on hard decel as well, but everything was rebuilt.
It's your turbos. I'm saying this not only because the symptoms describe bad turbo seals, but because any shop that rebuilds the stock turbos (which aren't T25, by the way, but rather TB022, which is a T25/T2 hybrid) to T28s clearly doesn't know what they're doing. And even if the shop knew what they were doing, the guy who paid for it didn't, and probably cut corners.
TwinTurbo.NET: Nissan 300ZX forum - A T28 wheel will be very inefficient in a stock compressor
P.S. Turbos don't need backpressure.
blue smoke
You are right... yea i pulled test pipes and its my passenger side turbo. I almost have it out right now. Pain in the *** btw without pulling motor fyi! The amount of shaft play was discusting... puttin new turbo in when this one is out... thanks for responding bud!
Glad you figured it out. I was more trying to say that with not so good seals, lack of back-pressure will accent this problem heavily. Free-flowing exhaust is best, but when you have issues to begin with, **** escalates quick. What are you going for replacement?
Prokopas
03-04-2011 02:03 PM
myfairlady
07-16-2008 02:48 PM
