Boost on 555cc injectors
Ok, I just ordered a set of 555cc Nismo injectors, all i hear is great stuff about them. My question is (not the common question, "HOw much HP am i making about?") How much can i safely boost with my new injectors? I want to know about where to set my high boost setting on my boost controller. I quick list of my mods are:
HKS Hi-power exhaust
JWT single Pop intake
Z1 Chipped ECU
Z1 525 Turbos
HKS 2.5 inch down pipes
Z1 Chipped ECU
Z1 525 Turbos
Originally Posted by Riz Z Speed
the 555 injectors aren't going to be your limiting factor.
the 555 injectors will take all the boost that those turbos will be able to handle. Rechipping of your ECU will be necessary.
How much boost you can run really depends on how built your engine is. If it's stock, it's not going to withstand as much as a hard core built one. With 555cc injectors, you'll prolly blow a gasket before running out of fuel.
if you want a definate answer then go with 2psi. thats a safe level.
Oh... the joys of using ASK JEEVES:
READ THIS FIRST:
http://www.zcar.com/forums/read.php?...29059&t=129059
http://zhome.com/rnt/DonnVBolton.html
http://www.sportcompactcarweb.com/pr...scc_proj300zx/
Read those.
17/18psi (I do that daily with my 555's)... your intercoolers become your limiting factor. Get aftermarket intercoolers and you can boost a little more on pump fuel, a little more than that on race fuel.
thetremendousti
08-14-2008 09:42 PM
jtmny1999
04-03-2003 07:40 PM
