BOV position
Guest
Posts: n/a
Re: BOV position
It realy doesn't matter. Both positions are on the same air pipe. Since you really don't need them, and since the stock ones are are up front, either position will work. Your not going to see noticable differences between the 2 positions. I have the Apexi one's and the go up front. They work just fine.
Re: BOV position
If you get the HKS ones, you should get the hard pipes and put them in between the intercoolers and throttle bodies, if you get the HKS hard pipe kit, it'll have a spot for them if I am not mistaken.
- john
- john
