Can u just bolt TT on to the VG30DE?
I'm sure I'm going to be blasted for this but I'm just curious at what are some of the diffrences between the VG30DE and the VG30DETT that would prevent you from just bolting on exhaust manifold and a couple of TT? If someone could take a couple minuets to explain it would be vary helpfull. I know that the VG30DE has a compression of 8.5:1. Which should be good enough for turbo's.
Newbie
Newbie
LOL No, you don't know.
VG30DETT's have 8.5:1 compression, VG30DE's are 10.5:1. You absolutely cannot bolt turbos onto a VG30DE.
Search... every NA owner has asked this question at some point in time. Easiest way to turbo an NA is an engine swap.
Welcome to ZDriver!
Start here: https://www.zdriver.com/forums/300zx-z32-tech-tips-273/how-make-n-faster-swap-mass-merge-thread-658/
i thought the DE was a 10.5:1 not 11.5
yup^^. pretty good read for the first few pages. you aren't supposed to do this, but honestly, another good read on it is on www.3zc.com tittled "fast N/A's?". i know it will answer the questions that you'll have next.
edit: not yup^^ snw, yup^^ nismo
Why? Because you want to do excess work for no reason?
The blocks are the same, but that still neglects the fact that the heads are different, plenums are different, etc.
Again I am forced to repeat myself... a flat out swap is the easiest way.
