clutch problems!
Guest
Posts: n/a
clutch problems!
about this time last year i just recently replaced the clutch plate...now i am getting no responce from my pedal there is no pressure at all i need to know what the hell it is our how i can find out what it is i have not yet been under the car yet but i will have it up on a lift this weekend so i need to know what to look for and what to do...if anyone could give me some advice that would be great. Thanx
check the fluid in the clutch resevoir. Is it full? Slave unit gone? Any particular reason why you didn't also replace the pressure plate? Been dropping the clutch at high RPM's? If so, you might have to get a new clutch disc. Let us know what you find.
Guest
Posts: n/a
ok here is what i have seen so far the fluid is full and the rod behind the peddal is pretty tight this weekend i am going to bleed the clutch but i need a better understanding of where the bleeder valve is i know its under the car but i dont know where exactly it is...i appriciate the help and the advice thanx
Darius
10-14-2005 09:04 PM
