Coolant Bypass w/pictures
Old 09-20-2010 | 11:28 AM
domsgarage's Avatar
Tough Guy
I guess no one knew what I was talking about?
Heres some pictures, its the throttle body water jacket bypass.
Here are some pics, the red is where the new hose is going, just let me know if its right.
Thanks
Uploaded with ImageShack.us
Old 09-20-2010 | 07:48 PM
xpwarrior's Avatar
It's been so long since I did the bypass I don't remember what all was originally there. I removed ALL of the small water lines and welded up the two 5/16" fittings on the heater hose stand pipes so I guess I did more of a removal than a bypass. Are you trying to keep the line that goes under the AAV? If so it would go from one heater pipe under the AAV then to the other heater pipe which looks like what you are doing in the first pic.
Not sure what you are doing in the second pic.
I don't even have an AAV anymore and have had no problems in the winter. I always thought they idled too fast when cold.
Old 09-21-2010 | 10:58 AM
domsgarage's Avatar
Tough Guy
The second picture is just running the hose from where the black hose is (on the left) to where the other pipe is (behind the oil pipe coming from the valve cover on the right).
I already deleted the aiv and pvrv or whatever it is, as well as the egr which you can probably see.
domsgarage
13
05-14-2012 08:16 PM
hardenstine
01-02-2011 11:56 PM
domsgarage
09-20-2010 04:52 PM
SHADY280
10-20-2006 07:57 AM
allmotor300z
04-22-2005 10:28 PM
