Correct Oil Pressure?
Old 08-30-2004 | 12:42 PM
lightspeed's Avatar
Southern Speedster
At idle I have about 30psi oil pressure indicated on my oil pressure guage. Underway about 3-4000RMB, I have about 55-60psi indicated. Seems low.
What is normal/typical?
Old 08-30-2004 | 03:03 PM
emo236's Avatar
confuzed member
But I belive that is correct. Do you have enough oil in your engine. Check the dipstick.
Old 08-30-2004 | 07:29 PM
91zxtt's Avatar
http://www.300zx.co.uk/tech/BuyingZ.htm
I was in the same ballpark on oil pressure until I installed k&N oil filter. Now, when the car is hot, the oil pressure is around 15psi. When it's cold, the pressure is higher.
Old 08-31-2004 | 07:38 AM
lightspeed's Avatar
Southern Speedster
Excellent info. Thanks.
Carl's Z
03-12-2006 12:09 PM
1ntegtype1
07-19-2005 10:45 PM
senkyoshi
01-15-2005 08:21 AM
senkyoshi
01-14-2005 05:36 PM
Chromedragon
10-21-2004 06:07 AM
