crank question
crank question
i need to find out if the crank for a tt is or is not the same as a na crank. i found one for like 75.00 shiped.any ways if any one knows befor i can call nissan it would help a lot
thanks
thanks
if it's $75 shipped, it's not any aftermarket crank that he'll want to put in his car.
http://www.amzperformance.com/z32/?p...71713f8f0f84d&
of course not everyone has my mentality "Go big or go home"
now correct me if i am wrong but i believe the crank is the same NA vs. TT the difference being pistons/con rods. now the max torque/horses that a stock crank can take...i couldnt tell you. but more probable the piston rings, pistons, con rods or crank bearings would go before the crank would. Something to think about
i wanted to add this article...scroll down to the paragraph on the crankshaft. very informative.
http://www.sportcompactcarweb.com/pr...scc_proj300zx/
Kyle over at import parts pro currently has a really good crank shaft pulley and belts on his grand opening sale for like 125... It's the ASP. I talked to him about it, the only difference between the ASP and the unorthodox is that the Unorth. is 1/2 a lb ligther and he said that honestly, they add pretty much the same amount of horsepower....
http://www.importpartspro.com/
