detonation sensor
detonation sensor
Hey Guys
Got detonation sensor code and correct me if I'm wrong, it's the 2 wire conector near the firewall. The wire from the harness end is busted off. Any tricks to get around it?
Thx
Mo
Thx
Mo
http://www.angelfire.com/geek/vg30de...tSenRel01.html
btw: i found this in like 20 seconds wth the forum search function.
you also might want to check and see if its the wiring or the detonation sensor.
http://www.300zx.co.uk/cgi-bin/manua...ault&total=190
then fix ... note there is a ghetto way to bypass the detonation sensor but you could cause serious damage to your engine by doing so
Thanks guys..I had check the work around on angelfire before I posted. The prior owner had cut one of the wires on the connector. HAd no problems until now. It's my understanding the sensor replacement and wiring requires engine removal which to me is not an easy fix. I would like to fix properly. Thanks for the suggestions
Originally Posted by MO1
...... It's my understanding the sensor replacement and wiring requires engine removal which to me is not an easy fix. I would like to fix properly. Thanks for the suggestions
I've been in a Z that had the det. sensor bypassed, and the detnotation is obvious when accelerating hard. You just need to be aware of it and drive in a way that prevents it.
50thaeturbo
02-16-2005 10:23 PM
