downpipe installation
Old 01-14-2007 | 09:44 PM
jnoble's Avatar
just wondering how manay hours should a shop be billing me for downpipe installation?? i just want to make sure im not getting ripped off on labour.
Old 01-14-2007 | 09:51 PM
do it yourself... you installe your IC i thought...
but for a shop should only take them a couple hours 2 i would think times there usual shop labour... 2 max anyways...
Old 01-14-2007 | 10:32 PM
jnoble's Avatar
yea but i bought the downpipes from this guy and he gave a good deal so i wanna through some work at him
Old 01-14-2007 | 10:39 PM
ahhh.... i still say do it yourself. save the work for when you come accross a problem or obstacle you cant handle or need help.
Old 01-15-2007 | 08:57 AM
b300z's Avatar
caught the z fever
its probably gonna take a lot longer than 2 hours
you cannot get to both of the downpipes easily with the tranny still attached. so you can either take the tranny off for easy access, or use some special tools and small hands.
heres an install guide without dropping the tranny
http://www.geocities.com/boostbyturbo/downpipe.html
you might be looking at 4 hours for the shop, around $400 from what others said
also its reccommended to get anything else possible or probable done if youre getting your downpipes installed...ie clutch, flywheel, rear main seal, tranny seals, driveshaft, etc...
Old 01-15-2007 | 01:17 PM
my bad... i was thinking the O2 housing wasnt the same part as the downpipe. on the DSM's ive been doing a lot of turbo swaps on lately for some reason its turbo/O2housing/downpipe/cat-midpipe/catback/axleback. thats the exhaust setup on them... soo a downpipe swap if the bolts turn freely would be an hour at most. we swapped out turbo from one car with no lift working abouve the engine in 1.5 hours. it was.... fun....
Old 01-16-2007 | 11:11 AM
ZLover4Life's Avatar
Encyclopedic Knowledge
Just a fair warning: if you can't do this on your own, the Z32 is going to be a VERY expensive car to own.
Old 09-03-2012 | 11:35 PM
Murph Z32's Avatar
Not trying to dredge up old threads, but I came across this doing a search. The link to the write up doesn't work anymore. Does anyone have a link on how to install downpipes? I would really like to install them on my Z.
Old 09-05-2012 | 04:45 PM
Murph Z32's Avatar
No one? I'd like to look at doing this myself to save some money.
Old 11-29-2012 | 07:07 PM
RobZ32TT's Avatar
I highly recommend removing the tranny, makes it so much easier. I had to buy new O2 sensors though because the holes that were on the new DPs were smaller. And there is a nut (not sure if right term) on stock ones that connects the O2 sensor and the stock DP. If that makes sense lol
87z
11-01-2011 12:19 PM
gryt57
11-18-2010 09:59 PM
lilt304
01-02-2010 09:25 AM
thxone
06-23-2008 02:07 PM
SHWAZ300
02-07-2005 03:37 PM
Quick Reply: downpipe installation
