Drivetrain swap
Drivetrain swap
I have done a conversion on my car from auto TT to a 5spd. My tranny, drive shaft, and rear subframe were all taken off an N/A. To the inexperienced I do not recomend this swap...very tedious. I also got rid of the AC, secondary air system, and HICAS systems. My problem is She won't start. I turn the key to accessory mode all the dash lights turn on,(as they should) i hear the fuel pump kick in, air works; but i turn the key to the start position and nothing...no click from the starter...nothing. To me this is a sign that either the starter is bad or I have a wiring problem. A friend said the secondary air system is a necessity because you can't bypass the program in the ECU...fact or fiction?? Someone HELP !!.............Does anyone know where i can find the wiring schematics for our car? (they dont have manuals such as a Hanye's or Chilton's here in Japan)
2in-trbo-z32
04-04-2005 10:55 AM
