ecu codes?? 3 long 1 3 short?
Old 08-03-2009 | 03:47 PM
silverz32's Avatar
the code i keep getting has 3 long flashes and then a second goes by another flash then 3 fast flashes is this a code 33 for o2 my engine lighte is not on when car is running i checked it because i think my pcu is crap
Old 08-03-2009 | 10:49 PM
Welcome to ZDriver!
You really need to work on punctuation so your sentences make sense. So you're asking what code 33 is? First google result: http://forums.nicoclub.com/zerothread/249406
33 is the left O2 sensor circuit.
Old 08-04-2009 | 12:03 AM
ZLover4Life's Avatar
Encyclopedic Knowledge
^2nd on making sense... I tried to decipher that earlier but I couldn't figure out where the question was.
If you got a code 33 and mentioned that it's the O2 sensor, replace the damn sensor... what's the issue? lol
And what is a "pcu"?
Old 08-04-2009 | 08:25 AM
napoleonzheking's Avatar
F5 Hero
that's true... the P is no where near the E.... not exactly a typo... lol.
Old 08-04-2009 | 01:02 PM
... and the C is nowhere near the T, so he doesn't mean PTU
Old 08-04-2009 | 04:13 PM
F5 Hero
this is why i love zlover....
Old 08-07-2009 | 04:46 PM
silverz32's Avatar
lol sorry I ment pTu I was typing to fast. The question is about the flashes on the ECU I just thought someone could tell me if that 1 flash in between the 3 long and 3 fast ment anything. thanks
Old 08-11-2009 | 02:32 PM
F5 Hero
http://www.ttzd.com/diagnostic.html
Old 08-11-2009 | 03:04 PM
KasbeKZ's Avatar
Pr0n Addict
the way he described it though, didn't he see 7 flashes? he said a pause, another flash, then 3 fast.
Old 08-11-2009 | 03:57 PM
Yeah... which is why I'm not sure how to answer his question. I've honestly never done the ECU self diagnostic, so my knowledge of how to answer his question (beyond knowing which codes mean which) is exhausted.
Old 08-11-2009 | 04:36 PM
bojo68's Avatar
Maybe it's Morse code...
Old 08-11-2009 | 05:03 PM
Here's an idea... try the O2 sensor diagnostic:
9. Start engine with the ECU in MODE II to enter MODE II - Heated Oxygen Sensor (O2) Monitor . The ECU is now monitoring the left O2 sensor. Warm the engine to normal operating temperature, then run at 2000 rpm for 2 minutes. Check that the LED blinks (or the check engine light) more than 5 times every 10 seconds at 2000 rpm.
10. To change to right sensor turn the ECU potentiometer clockwise with engine still running, wait 2 seconds, turn it back. Check the lights at 2000 rpm again for a similar switching condition.
NOTE: Light indicates signal from sensor to ecu. ON=rich, Off=lean. Blinking light means system is constantly adjusting between lean and rich which is normal. Any other indication would be abnormal and require further investigation. The switched on/off is 'closed loop', while a constant on or off is 'open loop'
11. To exit MODE II - Heated Oxygen Sensor Monitor, turn the potentiometer fully counter clock-wise and stop the engine.
If one (or both) of the O2 sensors fails, you know it was a code 33... replace the sensor and move on. If both of them pass, then we can worry about what that extra flash was.
Sharpshooter64
04-22-2014 04:43 PM
Seattle_Max
03-26-2014 04:47 PM
81SacUti280zx
03-07-2012 07:19 PM
MaxQ
06-22-2005 04:05 PM
modified300zxt
10-16-2002 10:15 AM
Quick Reply: ecu codes?? 3 long 1 3 short?
