Electrical problems
Electrical problems
Wassup guys I'm pretty new to this forum as a member but has always logged on as a guest. Anyway my dash board warning guages stays on, even with the key out and would stay running without the key. I managed to eliminate the constant running by changing the fuse box, but the lights on the dashboard constantly stay on. so far i checked the ignition switch, relays and fuses and thats not the problem. if anybody can help me out id be very thankful.
Remove fuses one by one to determine which circuit is giving you problems. Then you get to go on a wild goose chase. I'm guessing that one of the gauge panel wires got pinched along with a constant 12v wire and that's why they're staying lit.
licketysplit
02-04-2014 08:06 AM
