engine removal
Guest
Posts: n/a
Re: engine removal
Just pulled mine. And the Service manual isn't much help. Basically you have to disconnect everything. Electrical connection & hoses. Remove the radiator.Remove fan. remove driveshaft. Disconnect or remove transmission. Might as well remove it considering what it takes to get to the top bolts. Remove motor mount nuts and lift engine. Really over simplified here but not hard if you have the tools (putting it back to gether will be the tough part). There is a tech writeup on www.twinturbo.net but I only found it helpful as a reference. If you do it, or have any more specific questions about it let me know because it's still fresh in my mind.
TIP: take pictures and be **** about putting screws and such in labled zip-lock baggies. Should make reassembly easier.
'91 300ZX NA 2+2
'91 300ZX NA 2+2
